Clifford rsx 3.5 alarm door lock problem
Old Jun 16, 2004 | 04:12 AM
NJthunder5spd's Avatar
Default Clifford rsx 3.5 alarm door lock problem
i cant for the life of me figure out how they want this thing wired... i tried every possible combination and cant even get it to make any noise like its trying to lock/unlock the door..
Anyone else with this alarm or something like it where someone can tell me what wires on the alarm to use. I already know where the wires are on the drivers side kickpanel since i previously installed an alarm that went haywire! i know both of them are supposed to be negative according to the list in the tech section. so which wires from the alarm do i use??????
HELP IM LOST AND ANNOYED....
i managed to get the whole alarm installed with remote start but cant get the damn thing to lock.. go figure
Old Jun 16, 2004 | 11:18 AM
oneslowxa's Avatar
thin blue/ thin green in a 3 pin plug (the middle pin might be missing) of a tiny white connector on the brain... blue is unlock green is lock
Old Jun 16, 2004 | 11:50 AM
theres a relay at the end of those 3 wires: blue/red/green... i would assume i cut it off and use the thin wires then? of course i didnt think of that.. that would have been way too simple!
thanks
Old Jun 16, 2004 | 11:51 AM
oneslowxa's Avatar
yup that'll work
Old Jun 16, 2004 | 05:55 PM
yup it worked.. much appreciated.. now all i need to do is figure out how to make the unlock button pulse 2x when i press it once.
EDIT:
i managed to read the instructions for once.. yeah its amazing what they put in there. i found that they have settings and stuff that you can modify to make the alarm do whatever u want.. weird huh
Old Jun 17, 2004 | 02:35 AM
oneslowxa's Avatar
yeah instructions work... but there is also a wire in the passenger kick that you can tap into and it will unlock with a single pulse
Old Jun 17, 2004 | 05:48 PM
liucid's Avatar
i just did a viper 791 which is the same thing, all you have to do is put it on double pulse, which is menu 2 section 8, then push the unlock button. that should do it, this took me a while to figure out too. good luck
Old Jun 17, 2004 | 06:51 PM
yeah i did that.. theres a few other options that i still need to set so its exactly how i want it..... was thinking of the window roll down/up option next..
will keep ya posted
DaBlackBox
134
Apr 10, 2022 02:04 PM
mischadoll
Mar 9, 2015 05:48 AM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
