Can I fit these rims and tires.
Old Jun 1, 2006 | 03:40 AM
MikeC's Avatar
Default Can I fit these rims and tires.
Allright I found some 17x8 front and 17x9 rear wheels on a +35 offset. I want to use my 215/40/17 tires. Will this work out? Thanks in advance. I'm pretty poor so this is the only way I can offord that bip style, kinda. If I had enough money I would be buying Larry Flints Euroline DH's that are almost brand new!!! But that kinda money I aint gots. I'm just another poor Airman trying to make it.
Old Jun 1, 2006 | 01:18 PM
MikeC's Avatar
Anyone?
Old Jun 1, 2006 | 01:21 PM
CHPRBOX8's Avatar
i think you should be able to fit them
Old Jun 1, 2006 | 01:26 PM
MikeC's Avatar
Well once I can find out for sure I think I will order them.
Old Jun 1, 2006 | 01:34 PM
CHPRBOX8's Avatar
have you checked with a local tire shop to see if they can tell you if they will fit i woul call discout tire if you have one in the area
Old Jun 1, 2006 | 04:13 PM
MikeC's Avatar
That's not a bad idea thanks.
Old Jun 1, 2006 | 04:47 PM
RTon20s's Avatar
I would highly recommend getting a different tire for the rear. Hopefully you can find something in the same brand. Because even if you get the 215 to stretch on the 9" wheel it is going to look funny when compared to the front. You will have more stretch and a shorter sidewall in the rear compared to the front.
Assuming the wheels you want will work, and that you can reuse the 215/40s I would see if the tire brand and style you have are available in a 225/40 or 235/35, Unfortunately both of those sizes can be pretty tough to find. Especially if you are trying to match them to another tire size in the same brand and model tire.
Good luck though.
Old Jun 2, 2006 | 12:46 AM
evilBOXevil's Avatar
225/40/17 is very common size now. The big problem is that you're going to need to really need to space those rear wheels. I've got RH C5s (somebody correct me, but I think the offset is 40)on my box, with no spacers. The tires are a 215, and the rim is a 7.5", and I've only got about 1/2 an inch on the inside of the rear. Anything bigger will rub the inside.
a 215 stretched over a 9" rim sounds wierd to me. With the stuff you're talking about, you've got about 2" of space you're going to need to make in the rear...unless you've found some really badass staggereds with massive negative offsets, in which case--post some pics when you get them on!!
scionlife
371
Jun 2, 2015 11:00 PM
mama22
Mar 20, 2015 04:59 PM
DJ_OVERGOLD
Dec 8, 2003 11:44 PM
Flipper
Nov 12, 2003 02:39 PM
