DIY Intake CEL problems...
Old Jun 1, 2006 | 04:52 PM
Lilflip041786's Avatar
Default DIY Intake CEL problems...
I bought a Mass Air Flow Sensor intake piece and a filter the other day from Pepboys so I can hook up a temporary intake. I unhooked the battery, installed the intake, and then I hooked the battery back up. I start the car and it has trouble starting... but after about 30 seconds its running normal. I let the car run for about 10 minutes. Turn it off... then back on again with no problems. Take it for a test drive then the CEL turns on.
Does anyone know how long I should let the ECU "learn" that there's a new intake?
Old Jun 1, 2006 | 05:13 PM
ack154's Avatar
A 10-15 min idle should be plenty. What is the diameter of the MAFS section? Is it possible the MAFS was damaged?
Side question... why are you installing a "temporary" intake?
Old Jun 1, 2006 | 05:23 PM
I'm not sure what the diameter of the MAFS section is... but just to guesstimate I would say a 1 cen. bigger than the stock air box part.
I'm installing just to have something for right now... I'm saving up for F/I and the piece was only $20.
Old Jun 1, 2006 | 05:24 PM
And I don't think the MAFS was damaged cause I immediately transfered from the stock air box to the MAFS holder.
Old Jun 1, 2006 | 05:30 PM
ack154's Avatar
You could try to disconnect the battery again and then let it idle for another 15 min or so. See what it does.
What kind of a filter is it?
Old Jun 1, 2006 | 05:33 PM
Its just a no brand name filter from Pepboys.
Old Sep 16, 2006 | 04:54 PM
DJSupaFly's Avatar
reset your ecu by disconnecting your battery for a min of 5 min and then let it idle for at least 10 min. You will probably throw a CEL in the process but I am trying to figure out why that is happening. Also, it is a Power Adder filter, made by Spectre racing, am I correct?
Old Sep 16, 2006 | 06:30 PM
mike6789k's Avatar
just scan the code... that would help us answer your question
Old Sep 16, 2006 | 08:08 PM
DJSupaFly's Avatar
I think that the tubing you are using is a 3 in tube, and that is way to big to work correctly with our MAF. It is only used to 2.25 , soyou might look into a smaller piping or a piggyback eco like the emanage, to compensate.
whooty
Apr 19, 2023 05:34 PM
NinjaPilot
Feb 29, 2016 02:58 AM
BigIrish
May 18, 2015 12:04 AM
xb4lf
Apr 4, 2015 07:15 PM
bktply
Mar 17, 2015 04:50 AM
