A/C Condenser "Holed"...what "crosses"??
Old Jun 5, 2006 | 06:26 PM
tlzook's Avatar
Default A/C Condenser "Holed"...what "crosses"??
I've been told by the stealership that my A/C condenser has taken a"shot" from a rock or something and that it has a hole in it...That must be why the A/C hasn't worked since last fall.... I should be able to pull a condenser from a A/C equipped Echo at the local "yard" after I confirm the issue. Any other older model Toyotas sharing the same part or equivalant. Any help, ideas, hints would be greatly appreciated.....SC
Old Apr 13, 2007 | 01:36 AM
Aery's Avatar
I can sympathize, as I have the same problem, but sadly, no helpful hints for you.
Old May 1, 2007 | 09:42 AM
bB2NER's Avatar
Music City Scions
Check with a place online that sells condensers and cross check part numbers with an Echo. You might get lucky. Also now that so many xBs are getting wrecked you might be able to get one from an xB. Good luck and make sure you vacuum out the system and change the accumulator prior to re-charging it. Keep us posted please?
sabot7726
Apr 28, 2016 08:20 AM
Jus2tastee
Oct 1, 2015 08:57 PM
BlingSlade
Sep 5, 2015 08:52 AM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
