best power source for leds?
Old Jun 5, 2006 | 10:02 PM
rockcity11's Avatar
Default best power source for leds?
i got some leds and have been reading up on all the different power sources to tap into but i want to get some feedback on which one is the easiest/best to tap into. any feedback would be appreciated!!! thanks.
Old Jun 6, 2006 | 03:00 AM
H8me's Avatar
fused off the the main ingition is the only place i would get it.
DIRECTWIRE™ WIRING INFORMATION - SCION / XB / 2006 / Remote Start
[PRINT THIS PAGE]
12volts wht/blue (40A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock blue/white - driver kick, 14 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow/black (double pulse) - driver kick, 14 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/orange 5wi driver kick, 9 pin plug
Unlock Motor yellow/green 5wi driver kick, 9 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/white - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release brown/yellow - driver kick, harness to rear
Notes: Meter this wire while opening the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/yellow (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/red + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white/red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
carid
Nov 21, 2014 11:00 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
fliggah
Dec 25, 2003 01:03 PM
IceBox
9
Nov 4, 2003 04:35 AM
BlueBox
9
Sep 25, 2003 04:36 PM
