Turbo problems
Old Jun 9, 2006 | 03:41 PM
SO-CAL_TC's Avatar
Default Turbo problems
Hey everyone I installed a turbo kit over the weekend and now my car is being all weird. Every time I start my car (especially when its cold) I begins to idle really wierd and will even shut off some times. Why is this? any help is greatly appreciatted thanx.
Old Jun 9, 2006 | 03:49 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: Turbo problems
GReddy kit? What kit? What EMS too?
Old Jun 9, 2006 | 03:59 PM
SO-CAL_TC's Avatar
Its a custom kit. And I think its been this way since I installed the SAFC-ll
Old Jun 9, 2006 | 04:01 PM
paul_dezod's Avatar
Scionetics
KAD
Hmm. Could be the S-AFC, could be the O2 sensor being damaged. Could be the injectors. Any CELs?
Old Jun 9, 2006 | 04:06 PM
SO-CAL_TC's Avatar
Damn I bet its the 02 sensor cuz the filter fell off so it was just using regular air for I dunno how long. do you think its damaged? I just realized it this morning and put it back on here at work.
Old Jun 9, 2006 | 04:10 PM
paul_dezod's Avatar
Scionetics
KAD
It fell out? Maybe.....
Old Jun 9, 2006 | 04:11 PM
danman04x's Avatar
well if the filter fell of you might have damaged the MAF not the O2 sensor.
Old Jun 9, 2006 | 04:13 PM
Joe_Dezod's Avatar
If the filter fell off it would be a MAF issue. Your o2 is on your exhaust pipe in two positions.
Try resetting the ECU. When you disconnect the MAF and/or o2 without resetting the ecu it causes a fault and makes for a very rough idle.
If you have upgraded injectors, what size do you have? Theres a way we can help you compensate the larger injectors by trimming your maf signal to a certain extent with the safc. Let us know about those injector sizes if you switched them.
In the meantime, maybe the ecu reset will work .
Old Jun 9, 2006 | 04:15 PM
SO-CAL_TC's Avatar
What part is the MAF?
Old Jun 9, 2006 | 04:17 PM
SO-CAL_TC's Avatar
holy crap never even thought of that. How do I reset the ecu?
paul_dezod's Avatar
Scionetics
KAD
I just missed the part that he said his AIR filter fell off.
danman04x's Avatar
the the sensor right next to your air filter
Old Jun 9, 2006 | 04:18 PM
SO-CAL_TC's Avatar
^ oh
Old Jun 9, 2006 | 04:20 PM
davedavetC's Avatar
um... unhook the battery for a bit then hook it back up. then u'll have to reset your windows, clocks, sunroof, and the seat belt buzzer if you shut it off
Joe_Dezod's Avatar
The maf is on your intake pipe. It's a flat black piece with a wide harness plugged into it. It's located near your battery if that helps.
Put it this way... It's the only sensor attached to the same intake pipe your air filter is on. If there's something there, that's your MAF. Hope that helps.
Old Jun 9, 2006 | 04:21 PM
SO-CAL_TC's Avatar
sounds easy enough.
Old Jun 9, 2006 | 04:23 PM
SO-CAL_TC's Avatar
I have stock injectors. Well Im gonna try this out on my lunch break. Thanks for all you help guys.
Joe_Dezod's Avatar
I case you have a capacitor on your sound system or any other stored charge...
When you disconnect your ground cable with a 10mm ratchet (hint hint), open a door up. The dome light will help drain the car of what's left for an electrical charge.
As for the window initialization prodecure; just bring the window half way down (applys to both windows and sunroof), then pull all the way up on the switch and once the windows close keep pulling up for about 3 more seconds. Your windows should be set from there.
Old Jun 9, 2006 | 04:26 PM
SO-CAL_TC's Avatar
Kool thanks
Old Jun 9, 2006 | 04:42 PM
SO-CAL_TC's Avatar
Well I couldnt wait so I went outside made sure my filter was on there good and reset my ecu and it works perfect. Thank you very much for all your help. if someone would like to lock this thread thats kool.
