Turbo problems
Hey everyone I installed a turbo kit over the weekend and now my car is being all weird. Every time I start my car (especially when its cold) I begins to idle really wierd and will even shut off some times. Why is this? any help is greatly appreciatted thanx.
Its a custom kit. And I think its been this way since I installed the SAFC-ll
Damn I bet its the 02 sensor cuz the filter fell off so it was just using regular air for I dunno how long. do you think its damaged? I just realized it this morning and put it back on here at work.
If the filter fell off it would be a MAF issue. Your o2 is on your exhaust pipe in two positions.
Try resetting the ECU. When you disconnect the MAF and/or o2 without resetting the ecu it causes a fault and makes for a very rough idle.
If you have upgraded injectors, what size do you have? Theres a way we can help you compensate the larger injectors by trimming your maf signal to a certain extent with the safc. Let us know about those injector sizes if you switched them.
In the meantime, maybe the ecu reset will work
How do I reset the ecu?
The maf is on your intake pipe. It's a flat black piece with a wide harness plugged into it. It's located near your battery if that helps.
Put it this way... It's the only sensor attached to the same intake pipe your air filter is on. If there's something there, that's your MAF. Hope that helps.
When you disconnect your ground cable with a 10mm ratchet (hint hint), open a door up. The dome light will help drain the car of what's left for an electrical charge.
As for the window initialization prodecure; just bring the window half way down (applys to both windows and sunroof), then pull all the way up on the switch and once the windows close keep pulling up for about 3 more seconds. Your windows should be set from there.
Well I couldnt wait so I went outside made sure my filter was on there good and reset my ecu and it works perfect. Thank you very much for all your help. if someone would like to lock this thread thats kool.
