What Tires To Get?
Old Jun 12, 2006 | 07:43 PM
sp0t's Avatar
Default What Tires To Get?
Hey guys.. my stock potenza's are basically done.. and I have a 17x7 +40 offset wheel setup (My wheels are aftermarket, not stock.. if it really matters.)
So, I'm looking for some input on what kind of tires I should get. I'm dropped on S-techs and planning to get spacers so I don't want it to rub but I do want to clear up some of the gap that the S-techs left in the rear to make it look even at least. The stock tires were 215/40/17 I think.. I'm probably looking into 245/40/17 tires. Would you recommend this?
And for those dropped on s-techs and got bigger/fatter sized tires (17").. did you notice a gap change between the stock tires and your new ones?
Thanks in advance!
Old Jun 12, 2006 | 08:02 PM
TCTuNeR80's Avatar
I reccomend Falken Azenis RT615's
Old Jun 12, 2006 | 08:10 PM
2redgerm6's Avatar
falken or bf goodrich kdw. stock tire is 215/45-17 and i would stay with that size especially with s-techs. plus if you change size you change speedo and mileage and lose power (with bigger size). and i don't think 245s would fit a 7" rim.
Old Jun 12, 2006 | 08:53 PM
Schuller's Avatar
Do you still spin throughout 2nd gear?
Old Jun 12, 2006 | 09:20 PM
sp0t's Avatar
would you guys recommend 225/45/17 tires?
Old Jun 12, 2006 | 09:23 PM
DuMa's Avatar
225/45/17 in rt615 or hankook rs2.
cant go wrong with either tire
Old Jun 12, 2006 | 09:49 PM
sp0t's Avatar
does anyone have any pics of 225/45/17 tires on their cars? I want to see how wider they are.
Old Jun 13, 2006 | 01:05 AM
Spect2K3's Avatar
https://www.scionlife.com/forums/vie...673&highlight=
Read that through, i'd recommend the avon tech m550s...you won't need to buy a snow tire (if even needed), and they are GREAT overall tires according to MANY reviews
Old Jun 13, 2006 | 01:26 AM
nodsetse's Avatar
Um, they're 10mm wider than stock (which is just under half an inch wider), but the point is 225 is the widest you should go with 7" wheels, when using less than a 50 aspect ratio. You're in San Diego, so if you're interested in handling I suggest you go with a "summer" and "ultra" or "maximum" performance tire, rather than any "all-season" type.
Old Jun 13, 2006 | 02:23 AM
sp0t's Avatar
i'm debating whether or not to just get stock 215/45/17 tires or get 225/45/17's. I want performance tires that also clears up a little of the gap that the s-techs left on the rear.
Old Jun 13, 2006 | 03:28 AM
The_Instigator's Avatar
Id say stick with 215s. The overall diameter of a 225-45 is taller which may cause a little bit of rubbing with a lower drop. I have the TRD springs and 225-45/17 on 17x8 +35 and get a little bit of rubbing in the front wheel whels over bumps. Its not bad and the +35 offset is somewhat resposible. My next set of tires will porbably be the Azenis again but in 235-40/17 which is closer to the stock overall tire height. The Azenis RT-615 have exponentially more grip than stock so the 215s should take excellent care of you. I would recommend that tire more than anything else out there after very aggressive street and track use with it.
Old Jun 13, 2006 | 03:38 AM
io333's Avatar
after much research, when i need tires i'm probably going with goodyear f1 tires, because they are QUIET.
Old Jun 13, 2006 | 03:41 AM
melvynray's Avatar
www.edgeracing.com guarantee u they are the best price!
Old Jun 13, 2006 | 03:44 AM
melvynray's Avatar
http://edgeracing.com/2005/Scion/tC/tires/17/
Old Jun 13, 2006 | 03:57 AM
2_much_tc's Avatar
goodyear f1's quiet? yeah right. they are loud and the wear on those arent all that great. stick with something reasonably priced and get either falken ziex-512, or maybe even some kumho's 711 or the 712 supras. they are cheap, and the wear on those is minimal. and dont go 225. stay 215.
Old Jun 13, 2006 | 05:22 PM
Fsu1dolfan's Avatar
Just realized that they are in Miami...finally something close to me....plus FREE mounting and balancing.....Freaking awesome
Thanks!!!!!
Old Jun 13, 2006 | 09:59 PM
nodsetse's Avatar
Given your experience with them thus far and looking at the current wear, how many miles would you guesstimate they're going to deliver?
Old Jun 13, 2006 | 10:12 PM
Kilo6_one's Avatar
ditto: i run them as a daily driver tire....you may get 10k out of them? 200 treadwear is pretty soft compound so also it depends on your style of driving
Old Jun 13, 2006 | 10:15 PM
06SuperWhite_SoCal_tC's Avatar
10k miles out of the RT-615's ?
Old Jun 13, 2006 | 10:32 PM
I have had mine installed since March and have about 2-3000 miles on them including 2 track days. The tread depth is still very healthy with no signs of uneven wear. I would see them easily lasting me a full year at this rate and a non track car seeing up 18 months or more. Time will tell, but that is my assesment so far
