WIll 235-45R17 -93H fit a scion xb
Old Jun 16, 2006 | 04:05 PM
chrisnin's Avatar
Default WIll 235-45R17 -93H fit a scion xb
Thats the size of the tires on rims BSA i just bought, if not what wtire will fit on the rims and on my box. I have no wheel intelligence at all... Thanks for the help this website is awesome for Newbies>>>>>>
Old Jun 16, 2006 | 04:09 PM
ElChupacabra's Avatar
Well its really going to depend on the offset of the rim its on. I dont think you can get a 235 tire in an xB wheel well though. My 225s rub like a big dog...
Old Jun 16, 2006 | 04:15 PM
chrisnin's Avatar
so if thats whats on my rims, will anything else fit that rims,,, im so feakin unknowledgable.
Old Jun 16, 2006 | 05:10 PM
I think you need to learn more about the rims you have. Find out what the width of the rim is. Also find out what the offset is. You can measure the width of the rim with a ruler. On the inside of the rim there should be a number stamped somwhere that says ET##. It should have a number like ET35 or ET40. Something like that. Once you know these two things picking a tire is possible. Im certainly no rim and tire expert either but these are the basics....
Old Jun 16, 2006 | 05:22 PM
chrisnin's Avatar
thanks alot. Your help was great there 17x7.5 w a 35mm offset but it said et next to it not ee
Old Jun 16, 2006 | 05:25 PM
Well, on a 7.5" wide rim I would run a 205 tire or at max a 215. I cant believe they have 235s on there right now. Does the tread of the tire stick way out past the edge of the rim???
Old Jun 16, 2006 | 05:33 PM
chrisnin's Avatar
actually the rim say on the inside 7x7.0P and yeah there defintily 235 on it is that not cool, there not sticking past that far. i thought they were 7.5 because of it was worn away on the othr rim. so i defintly should not run that wide a tire?
Old Jun 16, 2006 | 07:32 PM
Boxer_Rebellion's Avatar
I wouldn't go any bigger than 215/45/17's.
Old Jun 16, 2006 | 07:55 PM
hotbox05's Avatar
215/40/17 is virtually the exact same as stock diameter wise.
CONCRETETC
Feb 9, 2015 08:05 PM
tc_Jake
Dec 31, 2014 01:45 AM
pro710
Dec 29, 2014 06:52 PM
