Valor exhaust tip install...
I installed an $8 tip over the stock tip with a wormgear clamp.
I have read that you need to pull out the tabs on the stock tip and wrench it off once the taps are no longer locking it to the pipe.
I hear it's a warm bisket (biscuit). Meaning it is hard to remove.
One reason I decided to just install over that stock set up.
so that wierd dip (pointing down) in the exhaust is actually a tip? does that mean that any exhaust tip will fit after the stock tip is removed? I want a tip to fill out the bumper since I dont need anymore exhaust noise that the xB already has.
Heres mine:
Pep Boys around $28.
I would imagine that _most_ tips would fit, some might look better/fit better to you. As stated above by xBHAWK, you can install some tips over the stocker.
Have you deadened the cargo area and rear hatch? Even if not for sound system purposes, it makes a world of difference in overall cabin noise levels.
"edited 9/16 to show image not link"
Originally Posted by tanakasan
Heres mine:
https://www.scionlife.com/gallery/?photo=17374
^^Just uses three bolts and goes right on with a wrench.
Not a hose clamp/wormgear type, if you can imagine a tripod w/3 bolts. I did remove the stocker. Its been on for a while and it stays put.
3A...China's finest!
I lost my first tip because I used the three provided bolts. Vibrations will cause these bolts to loosen and you may never see your tip again, have you seen my first tip?
I went with the worm gear clamp so that I could keep my big crome oval tip.
Water, (condensation) drains out the bottom bolt hole instead of dribbling out the exhaust tip.
Cut 4 slits in the pipe about 3/4inch from the inside end and put a wormgear clamp arount two of them.
Originally Posted by davesk8
Hi, just got the valor exhaust tip for my box.... has anyone installed this without lowering the exhaust? the directions say to.....
any help would be great!
thanks-
thanks-
-Alex
Hey xB'ers, a Valor tip update:
http://www.scionpartspeople.com/Sear...t+Tip+by+Valor
$31.90...not bad!
$31.90...not bad!
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
