Hatch Scion Emblem Removal
Old Jun 19, 2006 | 03:08 AM
lilitaliankid's Avatar
Default Hatch Scion Emblem Removal
Hey Guys,
Im in Boston right now, and Im not near my car, but Im planning a list of the things I need to do when I get back to NY
As far as the rear emblem is concerned, is it double stick taped on? or are there pin holes too? I want to paint it black then re-install it.
Whats the easiest way to take this bad boy off?
-thanks!
Old Jun 19, 2006 | 03:19 AM
roflitzjinno's Avatar
as i posted in your other one. its a double post. and BUMP cause id like to know how to remove this too.. just goo gone? i tried heating and prying it out but it was hard as hell to get out soooo there goes that idea..
Old Jun 19, 2006 | 04:16 AM
richardsayzz's Avatar
i removed my tC one and noticed how a couple of you guys put it on the front grille. i was wondering what you guys used to make it stay on
Old Jun 19, 2006 | 06:08 AM
Hyghgynx's Avatar
1. SEARCH!
2. SEARCH!!
3. SEARCH!!!
These questions have been covered before. Removal is easy...heat emblem, use floss or fishing line in a 'sawing motion', just be careful of the alignment pins on the front and rear "Scion" emblems. You can use Goo-Gone to get the left-over adhesive off your car, but its not necessary. To put it back on, you can use heavy duty automotive double-sided adhesive or a silicone adhesive. To actually paint your emblems, you're going to have to SEARCH for that one!
Old Jun 19, 2006 | 12:05 PM
Thanks so much for the response and sorry for the double post.
and just so you know i had already:
1.SEARCHED
2.SEARCHED
3.......SEARCHED
there are no other posts how to remove the actual scion logo, just the tC one (which i already did).
but thanks for reminding me to do that.
Old Jun 19, 2006 | 12:14 PM
Sanjuro's Avatar
Its pretty much the same process. Make sure you are aware there are two small tabs that fit into two holes in the body.
Old Jun 19, 2006 | 12:21 PM
thanks!
thats what i was looking to find out...i didnt wanna yank it off and not know that there were two tabs.
so im going to use goo-gone, a toothpick and elbow grease.
Old Jun 19, 2006 | 04:17 PM
Hyghgynx's Avatar
I just did a SEARCH...
https://www.scionlife.com/forums/vie...emblem+removal
Its all good.
Old Jun 19, 2006 | 06:14 PM
BADS33D's Avatar
1UP Crew
just use goo gone.
Old Jun 19, 2006 | 06:33 PM
Its all good.
hahahah if you actually read that article, its for the tC badge, NOT the scion emblem.
thanks tho [/i]
Old Jun 20, 2006 | 02:33 AM
MJVsTC's Avatar
Does goo gone have any effects on our amazingly durable paint finish?
Old Jun 20, 2006 | 02:52 AM
chrischoi's Avatar
mine got jacked by goo gone.. or maybe it was the paper towels... HAHA... def the paper towels.. i dunno.. i got some polish.. i'll put that on... just dont use a paper towel.
Old Jun 20, 2006 | 07:22 AM
Hyghgynx's Avatar
thanks tho [/i]
That method works for ALL emblems. Sheesh.
Old Jun 20, 2006 | 07:34 AM
amanda776's Avatar
I've been contemplating doing this for a while now, I'm still undecided.
Old Jun 20, 2006 | 08:24 PM
Jessicagmz's Avatar
As mentioned in the link above............yup, you might get adverse effects on your amazingly durable paint. I wouldn't know, and in that same token.......wouldn't dare
Old Jun 20, 2006 | 08:28 PM
ive removed badges from all sorts of cars
goo gone is harmless, as long as you use caution, and not a lot. Also, once you take off the emblem, wash the area with car soap and water, then put a coat of wax in that area to make sure it stays protected (just for safe measures)
ive never had any problems and I've done it a good 15 times.
Old Jun 20, 2006 | 08:42 PM
RoswellScion's Avatar
Put the goo gone onto a towel first. Don't apply it directly to the surface, and therefore, you won't be able to miss any and leave it on your paint to ruin it.
Old Jun 20, 2006 | 09:08 PM
brian's Avatar
goo gone is very abrasive and can take off clear coat. but if you're just taking off an emblem you won't use enough nor have it on the car long enough to have any negative effects
randomsuper
Dec 5, 2014 11:14 PM
nacy333
44
Oct 4, 2009 11:18 PM
