My amplifier adapter...
Old Jun 23, 2006 | 02:32 AM
mplex2000's Avatar
Default My amplifier adapter...
I know a lot of people just splice in a line out adapter to their car's wiring harness...but I hate tearing up the factory harness and I like quality parts in my car
This guy plugs in between the factory head unit and the harness to give line out and remote power signal.
Enjoy!
Old Jun 23, 2006 | 04:31 AM
TcPrincess's Avatar
nice, but i don't mind hacking wires up at all, just as long as it looks clean afterwards.
Old Jun 23, 2006 | 05:14 AM
mike6789k's Avatar
just two channel?
Old Jun 23, 2006 | 11:37 AM
mplex2000's Avatar
I never use fade so I may just use it to source all 6 channels.
Old Jun 23, 2006 | 06:45 PM
mike6789k's Avatar
true, but i like fade
are you just going to split the two amped outputs to all the speakers? bridge them? how does this work exactly??? what about impedance problems???
Thanks
Old Jun 23, 2006 | 07:01 PM
mplex2000's Avatar
Well, if I use this particular adapter without adding a second line out adapter, I'll probably run two pairs of tweeters off the head unit, then run a pair of RCAs to the back, split them to the 4 channel amp, then run a crossover RCA to the sub amp.
I'm also thinking of using a pair of custom 2 channel amps and electronic crossovers I built to run the tweeters. Otherwise I've already built passive xovers with excellent components for my Vifa mids/tweets.
We'll see how it sounds. I love the Vifas...going to try a less expensive sub this time (used a JL 10w3 in my Civic).
My main reason for using the stock HU is that theft is a big problem where I work..plus it already plays MP3s which is usually my main reason for replacing a factory HU.
Also, on impedence, years ago when I built my first "good" car system I used a 4 channel Hifonics amp to run all my speakers. My fronts and rears were bridged on the amp's front channel to give 2 ohms, and the rear channels on the amp were bridged to 4 ohms running a JL (10w0 I think? Long time now...). Sounded nice and didn't cost a lot.
Wow, that's a long post!
Old Jun 23, 2006 | 07:24 PM
mike6789k's Avatar
ahhh i see, you are still using a 4channel, just splitting the inputs
ok great, thanks for the informative post
pjl52
Aug 13, 2015 02:38 PM
trikkonceptz
Jun 7, 2015 01:46 AM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
cwong1001
Dec 3, 2014 03:30 AM
simplespirit
39
Feb 7, 2006 10:42 AM
