Do all tires have to match?
Old Jun 29, 2006 | 10:16 PM
ForceNut's Avatar
Default Do all tires have to match?
Hello Everyone-
So I got a nail in the sidewall of my rear driver side tire. I have Bridgestones. My question is, can I replace that one tire with another brand? OR should I stick with the Bridgestone??
Thanks and sorry if this has already been asked
Old Jun 29, 2006 | 10:28 PM
Hyghgynx's Avatar
As long as the tire is the same size as the others, you should be alright. Personally, It would bother me too much to have a tire not match the others (brand-wise). I'm **** like that! I would just stick to the same brand.
Old Jun 29, 2006 | 10:37 PM
nodsetse's Avatar
Default Re: Do all tires have to match?
I see a couple choices in this scenario. If you're happy with the current tires and they don't have too many miles on them, then I'd suggest getting the exact same brand & model as a replacement. If they're worn or you want to upgrade performance, then get a new pair of sticky tires you like for the front, and rotate your front tires to the rear.
You could get a non-matching brand/model of the same size, but that's only acceptable (imo) if you don't intend to do any "performance driving". It's best to at least have matching tires per axle (front or rear) for both safety & performance.
Old Jun 29, 2006 | 10:40 PM
FLIPAT's Avatar
I 2 got a nail in my tire, I replaced it with another brand, ofcourse the same size. Problem is the light for the tire presure keeps on turning on, now I don't know what's the cause of that but is really anoying. By the way I keep checking the psi on all the tires that's not the problem, so I really have no idea what's wrong with it.
Old Jun 30, 2006 | 03:10 AM
ForceNut's Avatar
Default varying size
I just talked to my uncle who works for a tire place and he said that tires of the same dimension can vary in actual size by 7% depending on the brand.
For example, the Yokema and the Bridgestones are labeled the same but may vary in actual size.
So word to the wise... stick with the same brand on all 4 tires so as to prevent odd wear on the tires.
Old Jun 30, 2006 | 07:44 PM
AnyVinyl's Avatar
having a different brand for one tire isnt that big of a deal
Old Jun 30, 2006 | 07:52 PM
FLIPAT's Avatar
I know it's not a big deal but it sure doesn't look and wear out the same as the rest, even dough is the same size. Also the tc has a very inteligent mechanism that can recognize something odd with the tires, that's the reason my light in the dash board keeps on turning on.
Old Jun 30, 2006 | 07:56 PM
yesti's Avatar
if you have the stock RE92's then you could change the two back tires to another brand and keep the other stock tire as a spare. if you have a spare rim then you could do a full size spare if you don't mind the fitment issues in the rear bay.
Old Jun 30, 2006 | 09:01 PM
BigPinoyTC's Avatar
Originally Posted by ForceNut
Hello Everyone-
The size does make a little difference but to be honest as long as its not to much bigger or smaller from the others it wont make a huge difference. Although try to keep the same size tires for the front. If you have 1 tire that is bigger or smaller than the other you can cause your car to pull one way instead of keeping straight.
Also you have to make sure the tires have the same tread design. If you have directional tires that are different than that would work because the tread is designed to pull a certain way.
Old Jun 30, 2006 | 09:51 PM
Woody6799's Avatar
I only get pairs...either 2 tires or 4... i would never just buy one tire
mc1114
Scion tC 1G Aero & Exterior
Apr 13, 2015 04:00 PM
pjpjr
Mar 30, 2015 09:11 AM
mischadoll
Mar 9, 2015 05:48 AM
Cadillac15
Jan 29, 2015 07:34 AM
