Has anyone thought off automatic window switches???
Old Jun 30, 2006 | 09:24 AM
Guamsilverbox671's Avatar
Default Has anyone thought off automatic window switches???
Hi, just got back and my computer was down for three months
Just wondering, the other day I was driveing my freind Lexus RX300 and notice something that I want in my box. His power window switchs automaticly rolls down all the windows with one touch each, and rolls it back up the same way. (without pressing them down while rolling) I notice that the switch configuration looks like it will line up on the xb's (though I see similar swithces on most Toyota Products).
Has anyone done this already? Wonder if the harness will match up, (though you will have to dissasemble the switches of the panel and put on the xb's panel.)
Did the search and found none.....
Thanks in advance.
Old Jun 30, 2006 | 10:40 AM
sstcrew's Avatar
I'm a bit confused here, I think mine actually do this.....
Old Jun 30, 2006 | 10:45 AM
dgHotLava's Avatar
i thought about it... but the properway to do this requires a lot of wiring and a window controler.
the controler is what will drop the window if it should happen to hit something while closing (like a kids hand or head. or even a stick of 2x4...) it keeps you safe and the car/window from being damaged.
Old Jun 30, 2006 | 10:47 AM
dgHotLava's Avatar
don't know much about the rs3....
but do you have auto down and auto up???
on more than the drivers window???
Old Jun 30, 2006 | 10:49 AM
kkawana's Avatar
after getting a pager alarm with remote window up/down feature all my windows do that from the drivers switches... 1 touch up/down for each window ... its nice
Old Jun 30, 2006 | 12:34 PM
dgHotLava's Avatar
yes a window module for an alarm will kinda convert the windows into this...
but it is also a small pain in the but because every time you want to lower the windows a small bit, it will try to send them all the way down.
then you need to push the switch in the oppisite direction to stop it from dropping all the way.
it works, but not as nice as a real auto up/down system.
Old Jun 30, 2006 | 12:54 PM
kkawana's Avatar
hmm.. will have to double check when i get into my car.. but think i can just go down with a lite push and release to get it to stop... or maybe its just the drivers window that does that...
Old Jun 30, 2006 | 01:05 PM
Cincycaddy's Avatar
Get two DEI 530t's. One for the front windows, one for the rear. This will give you one touch up/down on all windows. You simply tap down and they go down, up they go up. If you hold them down, then the windows will work like normal.
In order to get one touch from the passengers switches you'll have to run a pair of wires to each window switch.
Really a pain in the butt to be honest. Had it on my old neon, and am using a 530t strictly for one touch on my Miata (switches in center console so much easier to wire)
The nice thing is you can wire them off an alarm and have full remote capability to. OTOH, if you had enough time you could probably find a Toyota parts bin piece that would work.
Chris.
Old Jun 30, 2006 | 01:21 PM
dgHotLava's Avatar
Chris.
yes. thats how they work.
and i have always have window vents on my cars...so i would want to just tap the switch to get the window open an inch or two. then it would go open all the way ...
this annoyed me.
Old Jul 28, 2006 | 01:35 AM
Chris.
this annoyed me.
Thanks for the input.
Actually, I was wondering if I can use the swithches of the Lexus RX300, and retro fit it in my scion. The swithces seems to match-up with the panel, wondering if the harness will match-up too. I guess the only way to find out is to go see the dealer parts dept. and check and compare the swithces with mine.
Old Jul 28, 2006 | 10:54 AM
dgHotLava's Avatar
the harness will not match...there is a controler computer to them...our xB's (and xA's) have dumb windows.
the tC's have a simalar window controller.
i don't know if you ever looed inside your door, but there is an extra plug that would have gone to the controller module.
but the wires are dead ended inside the door hinge.
also the window motors would need to be swapped out. those motors have limit switches and jam sensors in them....our are dumb and do not.
i've been down this road...just letting you know what you are up against.
Inazuma
20
May 3, 2023 01:58 AM
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
IrjI619
Dec 21, 2014 05:04 AM
spawnconnery
Dec 18, 2014 08:38 PM
pier0723
Dec 3, 2014 03:38 PM
