scion06_tc
07-07-2006, 04:12 AM
I was wondering if anybody knows how to remove the steering wheel, and if its really hard cause i want to change it.
View Full Version : Removing steering wheel who Knows how???? scion06_tc 07-07-2006, 04:12 AM I was wondering if anybody knows how to remove the steering wheel, and if its really hard cause i want to change it. Neothin 07-07-2006, 04:32 AM should take about 2 minutes to take off. there are two torx screws around the back of the steering wheel (not necessarily on the back, but on the sides in the back). loosen those up and htat will allow the airbag/horn assembly to fall forward. IIRC the main nut that holds the wheel onto the hub is now accessable. engifineer 07-07-2006, 08:29 PM I highly reccomend disconnecting the battery for about 30 minutes before hand and even pulling the connector for the airbag harness loose to be good and safe about the airbag system. If they followed the standards I believe the connector will be yellow. Granted, it should not go off.. but it has happened before. SquallLHeart 07-07-2006, 08:59 PM Granted, it should not go off.. but it has happened before. happened before? i don't remember hearing about it. yipe :nails: but yeah... look for the yellow. when you open it up.. the wires are yellow too. engifineer 07-07-2006, 09:41 PM ^^ I havent heard of it on a tC, but I have heard of it happening on other cars with airbags.. The funny ones are thieves that were stealing peoples airbags and selling them.. those things cost some bucks.. some of them, however, were seriously injured because they took litlle care with them and they went off :D scion06_tc 07-08-2006, 02:34 AM Thanks i want to put a sparco,momo,bride,etc kind of steering wheel just not sure which one i want. Neothin 07-08-2006, 03:42 PM IIRC it's a t30 sized torx head bit scion06_tc 07-12-2006, 10:10 PM Does anybody know where i could a bride steering wheel!!! WeDriveScions 07-12-2006, 10:20 PM It's not that easy.... LoL Yeah, the torx bits are there, but there is a whole cable assembly that has to pop off, plus the shaft bolt as well... it'll take more than 3 minutes... it's pretty straightforward, but you will lose your horn, turn signal cancel, cruise control, and air bag... it's all in a ribbon cable that you have to disconnect. insanetc 07-12-2006, 10:21 PM wut about a quick release who has one and what do you do aftre you unscrew the steering whell from factory hub... WeDriveScions 07-12-2006, 10:54 PM I have one... You need a hub adaptor and quick release setup... you just connect the hub adaptor and then connect the quick release setup to the adaptor and you're good to go... The hub adaptor just bolts on with the stock nut and then the quick release attaches to that and then your wheel... insanetc 07-12-2006, 11:11 PM can you post a pic..which set-up do you have..and how is it..like getting out and driving u feel any diff... WeDriveScions 07-12-2006, 11:19 PM http://www.scionlife.com/forums/viewtopic.php?t=105289&highlight=hub+adaptor That's a thread of my quest to find the right parts... it's nice, but losing some of the features is a bit of a bummer... scion06_tc 07-16-2006, 04:49 PM Man i didnt know u lose the turnsignals i was hoping to leave this as a permanent mod!!! |
