has anyone experienced this audio problem?
Ok ill try and make this short.. I bout a new jvc headunit.. Radio wouldn't work and when I turned the car off and on the headunit would reset back to the default settings and my actual car would reset too..the clock goes back to 100 every time.. Its been in my car for about 24 hrs.. Its brand new, what did I do wrong? Someone please..
Could be a bad unit, could be bad wiring. Go get a smart harness for the Toyota (80-1761) and JVC (JV1680A) and try again. If that doesn't work, try exchanging out the headunit. could always be a Bad in Box.
Dude WTH are you talkin about you can't steal power from the clock, its in the instument cluster!
Radio 12v blue/yellow + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black/red + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- lt. green - blue +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
THERE no complaints. If you hardwired it in there are the colors. If you are using a aftermarket radio harness... just color match. Red, yellow, black, orange, and speakers. Should be no problem.
just double check the itty bitty tiny writing on the wiring harness.. most of the times the colors match up... but every now and then 1 wire or 2 is a different color...not just shade but flat out differnt color
thanks arite i got all that working, now, just no radio..im not sure at all how to look into fixing that problem, its plugged into the harness, but maybe the connection came off the other end..thanks tho guys for before
Beesh
Jan 9, 2015 06:30 PM
