Towing and Suspension
Hello, I have an 06 xB that I use for work. I wanted to know what types of springs and/or shocks/struts would help when towing without dropping the whole box a lot. I will be towing a trailer approx 500 lbs around the city a couple times a month. I have seen a couple of hitches on etrailer.com, but wanted to know where to buy one that comes out of the middle of the bumper or some pics of those with them and how they mounted them. Also, what do I need to wire up the tail lights?
Thank you in advance,
Chris
Chris
Originally Posted by cveklund
...what types of springs and/or shocks/struts would help when towing... I will be towing a trailer approx 500 lbs around the city a couple times a month... hitches on etrailer.com, but wanted to know where to buy one that comes out of the middle of the bumper or some pics of those with them and how they mounted them. Also, what do I need to wire up the tail lights?...
Curt makes the hitch. The hitch can be bought from them:
http://www.hitchsource.com/classitra...44fb3646ba0f12
You wil also need a wiring converter module, as the Xb's taillights are wired using a five wire system (euro) and most small trailer lights are wired as a four wire system (US). The converters can be bought at Hitchsource and many other stores.
Installing the hitch is easy, but not the converter, which can mess up the car's computer if you short the wires. U-Haul installs their brand of Curt hitches and the converter for about $350 with a guarantee.
Originally Posted by peteski
If you read the owner's manual, it doesn't recommend this car for towing of any kind.
If it is an automatic, consider a transmission cooler.
i just installed the curt hitch on my xb it is rated at 200lbs tounge weight and 2,ooolbs towing weight.. i have a friend who pulled to motorcycles about 400lbs a piece on a trailer to fla from s.c with no problems,, i have not towed my bike yet but i will be using a 4x8 trailer and i have the air ride susp on mine with will give me more ride height adjustment ill keep u posted once tow with it check out my profile but it is a easy bolt on hitch just 4 bolts good luck
SloTC1
Aug 16, 2018 02:45 PM
interestingmoron
Sep 16, 2015 06:59 PM
