Space between fender and tire
Old Jul 28, 2006 | 02:53 AM
MrTJT's Avatar
Default Space between fender and tire
Ok when i buy my 18" Rims im going to have low pros and i have Ground Control coilovers if i leave the coilovers set teh way they are is it still going to LOOK lower because of the differnet size wheel?
Old Jul 28, 2006 | 04:05 AM
dad719's Avatar
man i got 18's on mine and they still look small compared to other tc's i see on here with the same size rims.
Old Jul 28, 2006 | 04:56 AM
KooLAiD's Avatar
Maybe a little, but going to 18's will only get rid of about 1/2" of the wheel gap you have.
Old Jul 28, 2006 | 05:28 AM
dad719's Avatar
seriously man my rims look like 15 inch rims up close but far away they look bigger idk? its wierd though the rear ones look bigger whats the reason of that?
Old Jul 29, 2006 | 01:48 AM
2redgerm6's Avatar
getting bigger wheels will not get rid of wheel gap. you will still need to lower your car.
Old Jul 30, 2006 | 11:22 PM
dad719's Avatar
Yea man thats why im gonna save up and later on buy the coil springs for a 2 inch drop it will look alot better i think these tc's come with a huge fender gap dont you think?
Old Jul 30, 2006 | 11:38 PM
surfcity40's Avatar
this guy knows what he's talking about
look at this diagram:
the "overall diameter" is the "section height" of the tire (the sidewall height) plus the "rim diameter". when you use an 18" wheel, the tires mounted on them have a "section height" (or sidewall height) that is smaller than when using a 17" wheel. the total height of the wheel and tire is nearly the same regardless of the rim size.
this is why some "racers" opt to use lightweight 15" or 16" wheels because rubber and air weighs less than metal. their section height (sidewall) is taller.
buying bigger diameter wheels will not close the wheel gap, you will just have shorter sidewall tires. you need shorter springs or coil overs.
mvez
Scion tC 2G Wheel & Tire
Apr 1, 2015 12:37 AM
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
Mar 14, 2015 01:56 AM
mischadoll
Mar 9, 2015 05:48 AM
minter66
Dec 15, 2014 01:45 PM
smilygo
Nov 1, 2003 11:26 PM
