Door panel question
Old Jul 29, 2006 | 04:58 AM
brooke9490's Avatar
Default Door panel question
I am interested in re-covering my door panels in suede, the parts that heve the factory cloth on there now. Can someone please tell me how to get this piece off. Do I have to remove the door panel and cut it out or is that piece just an insert? I want to do the front door panel and rear panel so it all mathces my custom sub box that I just had wraped in suede. Any help on this would be greatly appreciated.
Old Jul 29, 2006 | 05:32 AM
Neothin's Avatar
IIRC that piece was stapled in.
I could be wrong though, i didnt look at it all too hard when i had my door panel off.
Old Jul 29, 2006 | 03:28 PM
Lilflip041786's Avatar
You do have to remove the door panel. I believe one panel is 3 pieces. Basically you have a top, middle and bottom. When I took mine apart I used a heat gun to heat up the places where it was all joined. I'll take some pics ASAP... I suck at explaining stuff...
Thats the driver side panel. Again I'll try and get more pics.
Old Jul 29, 2006 | 04:53 PM
brooke9490's Avatar
thanks for your help so far!
Old Jul 29, 2006 | 05:54 PM
Hyghgynx's Avatar
I'm interested in this also. I picked up some silver micro suede for my SSM to do this. So, if anybody can help-it would be GREATLY appreciated!!!
Old Jul 30, 2006 | 12:12 AM
OK, so I took some pictures of what I have undone. I haven't had any time to work on my rear door panels so here are some pics...
The back right panel "together".
4 Parts in all for the back panels. For the front is 3.
The Back side.
Closer pic of backside and the "joints".
Close up of a "joint". This is where I used a heat gun. I heated it up to where its about to melt then pried them apart.
"Joints" together but not permanetly.
Pic of the screws I used. Card is there for size comparison.
One of the tap screws in a "joint". Make sure when you screw these in you go straight down.
Final "joint".
Hope that helps. Sorry if I didn't explain it enough. If you need to me go more in depth on a certain part... just ask.
Where did you all get your fabric from??? and how much???
idriveanxa
Mar 8, 2015 12:03 PM
lunchbx05
Dec 29, 2014 07:53 PM
Joeynenj
Nov 25, 2014 05:29 AM
McG_XB
22
Feb 10, 2004 09:53 AM
shaefner
Oct 8, 2003 02:48 PM
