Short Shifter question...
Old Aug 1, 2006 | 01:37 AM
vanberge's Avatar
Default Short Shifter question...
So last weekend i installed the B&M short throw shifter, as well as brass shifter cable bushings.
I noticed today looking into my car from behind that it looks like my shifter is slightly tilted to the right (passenger side).
I don't notice a difference in the feel, and i dont have any problems getting into any gear.
The shifter does not have any free movement, and i'm pretty confident that the install was correct.
So, my question is: short throw shifter owners, does the changed pivot point make your shifter veer a little bit towards the passenger side instead of being completely straight??
Thx in advance.
Old Aug 1, 2006 | 02:54 AM
vanberge's Avatar
Forgot to say: this is when my car is in neutral.
Neutral position of shifter is slightly veered right (towards passenger side). just want confirmation that it is normal for short throw shifter. :-)
Old Aug 1, 2006 | 02:58 AM
BuddhasTC's Avatar
i have the TWM stage 2 and it looks pretty straight to me, i'm sure it's no biggy though
Old Aug 1, 2006 | 03:25 AM
tc2nut4's Avatar
i have the bm shifter... its probably not really off senter just you think it is... mental things... you know always waitin for something to go wrong... i think you're ok.. as long as all your gears go in you're good
Old Aug 1, 2006 | 05:17 AM
SquallLHeart's Avatar
as long as it's not loose in neutral... swinging back and forth, left and right?
should be fine.
Old Aug 1, 2006 | 06:19 AM
xnevergiveinx's Avatar
did you put the spring back in correctly?
Old Aug 1, 2006 | 07:00 AM
atmos_'s Avatar
it could because of the bushings. i'd go back and just make sure that everythings flush and fully tightened. if so, i wouldnt see anything to worry about so long that it's not affecting performance.
Old Aug 1, 2006 | 10:59 AM
vanberge's Avatar
My shifter is still tight in neutral... feels good.
And yeah im sure i put the spring back in correctly..
When i was installing my brass shifter cable bushings i had to kind of reem on the horizontal cable in order to get the bushing back over the pin. My friend said that he could see my shifter moving when i was doing that. I wonder if i pulled on it a little too hard?
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
