rubbing
Old Aug 1, 2006 | 05:52 AM
blk06_tc's Avatar
Default rubbing
if i have 3 inch drop in front and 2.6 drop in back will it rub with 18 inch rims on my scion tc
Old Aug 1, 2006 | 09:55 AM
melvynray's Avatar
should not rub much if any at all. ive seen lower drops with bigger rims w/minimum rub. someone correct me if im wrong.
Old Aug 1, 2006 | 12:57 PM
Otocan's Avatar
wow, you totally just threw the entire suspension geometry out the window... I hope you like driving a dangerous car....
anything more than 1.5" drop will lower the A-Arms below optimal suspension travel and cause severe loss of traction during suspension compression from extreme camber changes in the tire's contact patch.
Don't you love it when people do their research first before they mod their cars? Forget about your tires rubbing and start asking yourself whether your car is safe enough to drive on a public road. And what on bloddy earth could net you over a 76mm drop up front? The lowest coilovers I've seen drop it to 64mm.
Old Aug 1, 2006 | 03:22 PM
tc2nut4's Avatar
maybe he cut his springs
Old Aug 1, 2006 | 03:25 PM
blk06_tc's Avatar
skunk 2 lowering coils
Old Aug 1, 2006 | 03:32 PM
tc2nut4's Avatar
are those real coilovers... from what i know skunk2 only makes the slip on coilovers... if they are the slip on i pray to god you replaced your struts because if you've never had a strut blow at high speeds you'll have one soon without them
Old Aug 4, 2006 | 02:41 PM
Otocan's Avatar
umm... Skunk doesn't make springs for our cars....
Old Aug 4, 2006 | 04:07 PM
tc2nut4's Avatar
i'm confused... i just want personal clarification here. Are they lowering SPRINGS, coil-overs or "slip on" coilovers?????
Old Aug 5, 2006 | 06:52 AM
TeeCizzle's Avatar
x's 5!!....I totally agree no lower than 1.5 drop....no need any lower than that...unless you Air-Bag your car....
Old Aug 5, 2006 | 04:22 PM
tc2nut4's Avatar
still waiting on what exactly he has
Old Aug 5, 2006 | 06:35 PM
Yanki01's Avatar
wow, thats a drop! Your gonna have some SERIOUS problems with that! and IMO, that will definitely not look good! But ummmm post pics when you do!
Old Aug 9, 2006 | 12:48 AM
Yanki01's Avatar
he will seriously rub, maybe even with the ground!
Old Aug 16, 2006 | 02:27 PM
BOXMAN's Avatar
Before you look into rims or tires. Save for shocks and an alignment. I bet you are more than 3 degrees or more off of factory specs on your alignment
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
jtucker7
Apr 8, 2015 05:41 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
