Underglow On/Off with Unlock HELP!
Old Aug 1, 2006 | 06:16 PM
toby3002's Avatar
Default Underglow On/Off with Unlock HELP!
So I though it would be a neat idea for my underglow to blink along with all the other lights when i press the unlock button on my key.
I read through the tech sections on here and I found the necessary wires to lock and unlock the cars, but for the life of me, I cant figure out how to connect the underglow.
according to another thread on here, the wire for unlocking the car is located in the driver side kick panel, on the 20 pin connector, pin 14. I tested the wire, and it does indeed unlock the car when i touch a negative wire to it.
Im not the most experienced electrician in the world, so here's where I get stumped:
I have a positive an negative wire from my underglow, where do i connect them to make this work??? (I tried grounding the negative and touching the positive to the wire, but that doesn't do jack...)
HELP!!!!!!!!!
(oh and if this works, I will write up a tech article for anyone who is interested)
__________________
Old Aug 1, 2006 | 06:20 PM
vmains's Avatar
Way cool idea. I look foward to finding out how it works. Good luck
Old Aug 1, 2006 | 07:28 PM
hawgs74's Avatar
want to do the same thing -- will be watching for more info
Old Aug 1, 2006 | 08:14 PM
chanman's Avatar
well the lights blink when you lock/unlock. Try splicing the parking light wire.
Old Aug 1, 2006 | 08:36 PM
toby3002's Avatar
if i did that my underglow would come on when i turn on my lights...no can do
Old Aug 1, 2006 | 09:07 PM
tegrenath's Avatar
IIRC, krdshark did this with his underglow kit and it burned out pretty quickly. I'm pretty sure he's a member here, but I know you can get ahold of him over at YSTC.
Old Aug 1, 2006 | 09:14 PM
theSciontologist's Avatar
PM Rjonsey... i know he did it with the interior lights... so when you open the doors they come on... neat idea not sure if he did it with the signals....
Old Aug 2, 2006 | 01:08 AM
krdshrk's Avatar
What I had done is my underbody LED kit was tied in to my parking lights. When i locked/unlocked the door, it would quickly flash the underbodys...
Except.... the constant locking/unlocking means that it's a short power surge to the led control box. First it blew fuses.... then it blew the control box.
My recommendation: Don't do it.
Old Aug 2, 2006 | 01:20 AM
toby3002's Avatar
pmed krdshark, bump for more info...
Old Aug 2, 2006 | 01:50 AM
toby3002's Avatar
i have neons...no led control box for me
Old Aug 2, 2006 | 03:20 AM
toby3002's Avatar
well im gonna try it anyway...so where the heck is the wire for the parking lights? the schematic i have says top of fuse box, 30 pin connector, number 29, brown, but i cant really see how many pins are on some of these
Old Aug 2, 2006 | 03:45 AM
cherryBox's Avatar
I would check out the tC install thread for the puddle lamps. same concept. added bonus is you get the underbody on when the doors come open.
puddle lamp install: https://www.scionlife.com/forums/viewtopic.php?t=117628
I just finished doing my puddles (xB) and tapped directly into the wires that feed into the dome light switch. whatever position that switch is in, I know what's gonna happen.
the catch here is that you'd be powering the neons from two sources and you wouldn't want the power going upstream thru the dome lamp. some inline diodes would solve that. the other (potentially HUGE) issue is the power draw that the neons pull. could really fry some stuff that way.
Old Aug 2, 2006 | 04:11 AM
krdshrk's Avatar
I don't know which one you need to wire it into... the flashing was kind of a by-product of the install of an alarm system
Old Aug 2, 2006 | 05:18 AM
toby3002's Avatar
alright well i did it! i tapped into the drivers side door motor and it flashes once when i hit the unlock button on my key or inside. I'll post a DIY as soon as i upload the pics
Old Aug 2, 2006 | 06:12 AM
toby3002's Avatar
the link: https://www.scionlife.com/forums/vie...763895#1763895
Chrisb319
Scion tC 1G ICE & Interior
11
Sep 12, 2008 12:14 AM
americandesi
22
Jul 27, 2008 06:56 PM
jmoney
Feb 8, 2007 11:37 PM
pocketbusXB
16
May 7, 2006 05:34 AM
datboidere2
Mar 10, 2006 06:35 AM
