Which wire is a good 12v source in the driver side area?
Here is almost every wire color you would need on a tC.(Except ECU wire colors) You should be able to take of the plastic bezel that goes around the steering column to access the power wires.
05 Scion tC- Wire colors
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch[/quote]
Originally Posted by Jake_tC
Is the grey "accessory" wire the switched 12 volt?
Originally Posted by tc2nut4
isn't he going to want to tap into one of the headunit wires??? for the dimmers or are you gonna keep your gauges lit all the time...???
yes defi gauges are nice. i have a couple of friends who own them one has them in an sti and the other in a wrx. very nice gauges.
they wanted me to get them as well but i opted for the greddy gauges with the silver face and amber back lighting. they match the stock gauges a little better.
minter66
Dec 15, 2014 01:45 PM
