Autometer Air/Fuel gauge wiring?
Well I tried this as well and if you want the gauge functional then dont bother. You will have to hook it up to the second sensor and it will only give you a lean reading or a rich reading. Nothing in between.
Originally Posted by zer0
Originally Posted by Scott8
The intructions said to hook to the wire coming from the ecu before the 1st sensor?
The autometer afr gauge, is a narrow band gauge. The tC uses a wide band afr gauge. It will let you konw if your RICH or LEAN but wont give you exact reading. A Wideband gauge is alot better look into the AEM UEGO is a real good choice.
Does Autometer even make a wideband?
http://www.autometer.com/cat_gaugede...gid=3606&sid=4
Originally Posted by jjos1
Is there any way of getting a wideband with the oem manifold (without gutting the cat) I want to get a wideband also but I dont want to get a header (my car sounds perfect right now) ?
I have mine on the spipe right before the second o2 sensor and I have not cats and I read 14.7 at idle. So Cats or no cats youll get a correct reading. I wouldnt mount it past the spipe though. you wanna stay within 36 inches of the exhaust outlets on the motor.
Nice, I have my eyes set on a ultra lite wideband just din't want a header. Off topic but any one have one of these ?
http://www.autometer.com/cat_gaugede...id=3495&sid=11
I have the Haltech setup, from www.speedmachineperformance.com
www.performancetrends.com also makes a nice wideband gauge.
just like everyone else stated, just get a wide band. 1st reason the sensor is after a cat and that will throw the reading off. 2nd you cannot get a accurate tune with a narrow band sensor. 3rd wide band is perfect for tuning.
my06tc
Jun 25, 2015 12:18 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
mattjk
121
Dec 22, 2004 10:49 AM
