A newbie question please dont flare 18x7.5 43 offset?
Old Aug 4, 2006 | 06:33 PM
DonnyDarko's Avatar
Default A newbie question please dont flare 18x7.5 43 offset?
G-games 18x7.5 43 offset with 5X114.3/100 bolt pattern...will I have any problems with this on a tC with no drop? Sorry for the newbie question.
Old Aug 4, 2006 | 07:29 PM
Neothin's Avatar
you could run that with an s-tech drop with no problems. Go for it.
Old Aug 4, 2006 | 11:04 PM
Hyghgynx's Avatar
You should be aiiight. Your rims will still be tucked in the wheel wells since stock is +45. (Even though you're getting 18s.) Personally, if you want the more flushed look, you should be looking at rims in the +38 - +33 offset range.
Old Aug 5, 2006 | 03:12 AM
Neothin's Avatar
spacers will work too. You're ideally going to want a 10mm up front and a 15mm out back, but alas, i've yet to see a 10mm spacer for us
Old Aug 5, 2006 | 03:29 AM
DonnyDarko's Avatar
...Ill need spacers
Old Aug 5, 2006 | 03:35 AM
surfcity40's Avatar
you won't "need" them but it will change the look. the higher the positive offset the more they will look "tucked under" your car. the lower the offset, the more "flush they will look against the fender.
http://home.cfl.rr.com/icdedppl/faq.html#d3
Old Aug 5, 2006 | 04:40 AM
DonnyDarko's Avatar
Ahh okay...hmm sounds good how much would those spacers run me and what size spacers would u recommend?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
tC6M
Nov 26, 2014 06:44 PM
JChan428
16
Dec 15, 2003 09:24 PM
