Got several querstions
First i want to say thanks to paul dezod for replying to some annoying noob questions so quickly however, i have a few that i would still like answered....
1) I am looking to turbo my a/t tc but it is my one and only daily driver. So i was told that i could get a 3psi spring to run normally and get a boost controller if i want higher. Do y'all think the 3 psi spring would be best because less boost means less stress? Or would it be best to leave the 5 psi spring in and take it easy for a couple of 1000 miles so i don't strain the engine when i turn up the boost?
2) How do boost controllers work? Should you be parked when you change boost?
3) I have read quite a bit about the scion's a/t tranny limitations but have found quite a range of opinions so i am guessing that no one really knows. So do y'all think that since the dezod kit comes set with a 5 psi spring that 6-7 psi isn't out of the question. I know the internals can take that but i guess the tranny is the only question mark.
Thanks.
Thanks.
Thanks.
Thanks.
1) Well your driving habits and your final tune will dictate much of your luck with your motor and transmission. Beating on it will only cause more headaches if you do not want to build the motor.
2) You can change the boost on most controllers on the fly or park. This depends on the kind and brand boost controller used.
3) You can run more boost, but refer to the 1st question I answered for more explanation.
Originally Posted by djafropiq
I wanted to add another question if I could.. I got a hks exhaust and I was wondering if I were to get the s1 kit.. Starting from the downpipe on down
I wanted to add another question if I could.. I got a hks exhaust and I was wondering if I were to get the s1 kit..what other extra exhuast pieces I would need Starting from the downpipe on down
One more question.. I've noticed that you always tell people to tune their car after installation.. I thought that was what the emanage was for
Nice..I don't know how much enviromental issues would factor into my use since I live in sunny room temperature CA but I'm sure the sr20 tuning guys I know can help me out.. Last question.. I can spread the cost of the kit over a few credit cards right? Haha
I guess....Call me tomorrow to work something like that out.
