OKAY....GOT MY NEW BOX!!!!
Old Aug 8, 2006 | 06:19 PM
JAEGER_FAN's Avatar
Default OKAY....GOT MY NEW BOX!!!!
Now I need somemajor help. I need to know what I should do for rims. Here were a couple choices,
19" x 7.5 w/40mm offset w/ 215/35/19 tires
18" x 7.5 w/40mm offset w/225/40/18 tires
Then I want to lower it about 1.5" or 2".
So I guess my real question is Which one should I do? I want a 2" drop but if I go with 19" I know I cant really. I really want 19's though. Or....do I go with the 18's with a 2" drop. I am confused because the rim places tell me different things. Like I need the right offset and lowering and tire to look right and fit right. All this I understand but all give me different answers as to what is the right combo. So I now turn to you all because you all own this car too and you all know more than I do about what you can and can't do on the XB.
All help is appreciated VERY much you guys.
Thanks
Old Aug 8, 2006 | 06:23 PM
hayalex6's Avatar
IMO, I'd go with 18's. 19's are just huge, and also rub when you drop it 2".
Old Aug 8, 2006 | 06:48 PM
JAEGER_FAN's Avatar
So if I do like an 18" X 7.5 40mm offset rim W/215/35/18 tires and a 1.5" drop will they be flush with the wheel wells? I dont want the tires to stick out or tuck under.
Old Aug 8, 2006 | 07:45 PM
hayalex6's Avatar
you will want a lower offset, or you could always get wheel spacers.
Old Aug 8, 2006 | 08:08 PM
JAEGER_FAN's Avatar
So do I need two different offsets for front and rear then?
Old Aug 8, 2006 | 09:32 PM
JAEGER_FAN's Avatar
Then what about a 1.5" drop? Will Ineed camber shims?
Old Aug 8, 2006 | 09:37 PM
hotbox05's Avatar
215/35 18 or 225/25 19's.
are my reccomendations. 225/25/19's will be very expensive but still stock diameter and look SWEET. gigantor!!!
Old Aug 9, 2006 | 03:07 PM
JAEGER_FAN's Avatar
Yeah...that would be cool but talk about a rough ride. 25's are pretty much like riding on just your rims.
Has anybody heard anything or seen 2tonlocksmith's Xb? He has 19's with 35's and has it bagged. I would like to know if he has any rubbing issues.
Old Aug 9, 2006 | 06:07 PM
Dwestxb's Avatar
I've had 17's ,18's & 19's on my xB with a 2" drop, none of them rubbed.
215/45/17
215/35/18
215/35/19
Old Aug 9, 2006 | 10:04 PM
mi-caha06's Avatar
Go with the 18's.
Old Aug 10, 2006 | 02:26 PM
Subcompact Culture's Avatar
Who makes a 225/25/19? I haven't seen a 25-series tire that narrow before.
Old Aug 10, 2006 | 03:46 PM
JAEGER_FAN's Avatar
Dwest...what were your offsets on the 19's and 18's?
Old Aug 10, 2006 | 04:00 PM
Xmanjr's Avatar
Scion Dynasty
From my experience. Id go with 215/35/18
225/35/18 if they make them
Dont go with a 40 profile you will rub
Good Luck!
Old Aug 10, 2006 | 06:12 PM
JAEGER_FAN's Avatar
Does anybody know what rim offset is the best on an Xb? 38mm,40mm, 42mm, to make them flush to the side of the wheel well?
Old Aug 10, 2006 | 06:40 PM
Search the wheel/tire forum. There are tons of threads with this info.
Old Aug 10, 2006 | 08:32 PM
beach808boyz's Avatar
i don't want to threadjack or anything but i have a really quick question about the tires.
is a 35 series tire even safe? will going over potholes and stuff be a problem? thanks in advance
Old Aug 11, 2006 | 02:41 AM
hotbox05's Avatar
Good Luck!
you will rub with a 225/35/18 as well.
airmankevin1
Nov 17, 2015 05:44 AM
Schmohey
Oct 4, 2015 02:53 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
prescottn
Sep 22, 2015 01:30 PM
spharr62
Sep 20, 2015 01:44 AM
