wiring the HKS Type-1 turbo timer?? Need some help
Old Aug 12, 2006 | 03:39 AM
TURBO_TC02's Avatar
Default wiring the HKS Type-1 turbo timer?? Need some help
Need some help here from you guys that are already T/C. and have a an HKS Type-1 timer. need some direction here....especially with the speed sensor, any help i can get that would be great!!!!
Old Aug 12, 2006 | 03:51 AM
ProshopXB's Avatar
Almost every wire you would ever need for the tC.
05 Scion tC- Wire colors
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch
Speed Sense:purple /AC/ ECM, 2nd plug from top, pin 17
Old Aug 12, 2006 | 03:54 AM
TURBO_TC02's Avatar
OMG well i will definatly have to print that out thanks man!
Old Aug 12, 2006 | 03:55 AM
ProshopXB's Avatar
No prob, it is definately handy to have around.
Old Aug 12, 2006 | 02:41 PM
tc2nut4's Avatar
^^^ you prove to be a neverending supply of knowledge time and time again
Old Aug 12, 2006 | 03:04 PM
yamaha16bw's Avatar
I just wired up my TT with the help of proshopXB and it worked out just fine. good luck with the install. Its not too hard once you know the right wires.
Old Aug 12, 2006 | 03:11 PM
tc2nut4's Avatar
I can't believe no one makes a harness for our car yet might be a good thing to sell HINT HINT
Old Aug 12, 2006 | 03:35 PM
TURBO_TC02's Avatar
Thanks yamaha im going to give it a good try, but we'll see..i'll be sure to let everyone know how it turns out. TC2NUT, no they don't make a harness yet i was talking to Paul Dezod on the phone and he said i should just hard wire it into either the sterring collumn or the e-management system, so i think im going to try the collumn. I just bought it why would i sell it bc im going to have to do the same thing for anyother turbo timer??
Old Aug 12, 2006 | 03:38 PM
ProshopXB's Avatar
TC2NUT meant sell a harness that allows you to plug and play the TT, no splicing, like with Supra's and WRX's.. I second hooking your wires to the steering column, that is the best place to do that.
Old Aug 12, 2006 | 03:39 PM
tc2nut4's Avatar
^^^ yes that is what I meant
Old Aug 12, 2006 | 03:40 PM
TURBO_TC02's Avatar
Oh ok i got ya i totally misunderstood him, ok well thanks for all the hints and tips guys much appreciated!
Old Aug 12, 2006 | 03:42 PM
ProshopXB's Avatar
Oh and Bryce good luck with getting any TT company to make a plug and play option, they usually only do this for cars that come from the factory with turbo's already installed. But it never hurts to want and dream.
tc2nut4's Avatar
hope all goes well, i was going to install one when I had my SC... but yeah we all know what happened there. Damn toyota
Old Aug 12, 2006 | 03:49 PM
TURBO_TC02's Avatar
thanks tc2 i will get picks as soon as possible with the finished product
Old Aug 12, 2006 | 04:09 PM
tc2nut4's Avatar
please do, maybe a DIY is in order????
Old Aug 12, 2006 | 05:15 PM
TURBO_TC02's Avatar
yeah man i will give you a complete step by step process when everything is done and in order. i'll keep you posted
Brammi
Nov 13, 2016 03:46 AM
Flyfishfreak
Jun 10, 2016 02:55 AM
my06tc
Jun 25, 2015 12:18 AM
clickclickw00t
Feb 18, 2015 08:57 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
