HID kit burnout stock wiring
Old Aug 15, 2006 | 01:20 AM
PIMPmyPride's Avatar
Default HID kit burnout stock wiring
I bought a Bi-Xenon hi/low kit and installed it according to the sellers instructions and all went fine since the 11th. This afternoon I discovered the right side light was out completly, no highs or lows. So I check all the connections, fuses, bulbs, and nothing changed. So I removed the HID bulb and replace the stock halogen and the bulb is very very dim, dimmer than the pocket flashlight I was holding. The left side is fine .
So anyone have any idea what happened? I'm taking this in to the dealer first thing in the morning to see what they say. I just hope it isn't something major and will be covered under warranty. I have removed that kit and replaced the halogens back to stock. Hopefully they won't know there was ever an HID kit there to begin with. I did use the wire harness, but it had to be reconfigured to work with the H4 headlights.
Old Aug 15, 2006 | 02:28 AM
bb05's Avatar
hey i had the same problem with mine. you dont have to take it to a dealer. the xb come with a 10 amp fuse just change it to a 15 or 20 amp thats all.. i know exactly what you mean about the light being dim it scared me to but its just the fuse. and if its not that well then take it to the dealer.
Old Aug 15, 2006 | 02:32 AM
I'll try that and see if it changes anything, hopefully it does. Thanks.
Old Aug 17, 2006 | 07:46 PM
365Motorwerks's Avatar
Hope it was just the fuse, if you put the HID's back in use a relay harness so you skip the stock wiring..
Old Aug 17, 2006 | 08:08 PM
It was a fuse, I checked it and replaced the fuse then reinstalled the stock halogens for the time being until I get the relay harness in to install.
Old Feb 2, 2007 | 02:33 AM
micaxB's Avatar
same problem here. except my headlights dont turn on..u think it's a fuse or my wiring harness?
hoping its my fuse.
Old Feb 2, 2007 | 05:09 AM
micaxB Posted: 2/1/07 8:33PM Post subject:
hoping it my fuse.
Stock lights don't come on, or Hid's? If it's the Hid's wire them right up to the battery just to test to make sure they work if they do then check your fuses sometimes the ballasts need extra power to start up which is where the relay harness comes in as the extra draw will sometimes pop fuses or not even allow the ballasts to power up fully on a factory harness, good luck..
Old Feb 2, 2007 | 05:24 AM
micaxB's Avatar
the HIDs came one for a lil bit then i moved the ballast around to another place (car off) but kept the exact wiring an after that it doenst work anymore.
stock lights dont come one either. one side did (really dim) and then it just went out.
hoping its only fuses. going to get some tomarrow!
is running a higher amp fuse recommended or should i stick with 10 amps?
how much would a new harness cost me anyways..if the dealer wouldn't do it for me.
Old Feb 2, 2007 | 05:32 AM
I'd replace the fuses with the stock halogen lights to make sure everything is cool, stick with the stock rating on the fuses. Once you get the halogens rocking again just hit me up on my site for a relay harness for your hid's I have them prebuilt for less than you can make them for!
Old Feb 2, 2007 | 11:34 AM
micaxB's Avatar
and this harness you're talking about would work on my hi/lo beam hids? (hi -halogen)
edit*
before school today i check my fuses and both are blown. going to buy some after school and come back and update.
Old Feb 2, 2007 | 03:06 PM
edit*
yep
Old Feb 2, 2007 | 07:05 PM
micaxB's Avatar
it was the fuses. everything works now!
Old Feb 2, 2007 | 07:21 PM
Grime's Avatar
edit*
yep
how does this harness work/install?
Old Feb 2, 2007 | 09:28 PM
Has a relay that connects to the battery, and a H4 connector that goes to the driver side factory H4 connection so your headlamp on/off switch will activate inside the car...from there there are two connectors for the hid ballasts (9006 ends) one long for the passanger and a short one for the driver side...if you have a hi/lo setup instead of a single hid it also has stubs that you connect the halogen bulb to using butt connectors..
Old Feb 3, 2007 | 03:34 AM
Grime's Avatar
Interesting... so are you planning on coming to the Elk grove Best Buy show at the end of the month? If so I would pick up a harness from you
Old Feb 3, 2007 | 08:12 PM
Baged_xB's Avatar
StyleWagons
hmmm 365Motorwerks, perhaps we need to make a sticky since we both sell HIDS about the dangers of purchasing kits that draw ALL thier power from the stock harnesses.
The stock harness is NOT designed to take all the draw from the Ballast startup amperage. some ballasts can take 20Amps per ballast . thats pretty high for a circuit that spike at 10amps that combination equals blown fuses or charred wires or worse a fire in the engine bay.
Old Feb 4, 2007 | 04:04 AM
Possibly but I'm still not sure on what shows I am going to yet..
mischman
Jan 14, 2015 06:07 PM
jaspercanda
Dec 28, 2014 10:09 AM
Basebllstar
Dec 17, 2014 07:30 PM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
