18x7.5 and hotchkis drop (tC) - will et35 rub?
Old Aug 22, 2006 | 03:50 AM
exige's Avatar
Default 18x7.5 and hotchkis drop (tC) - will et35 rub?
will a 35 rub on that setup? i really dont wanna get a 45, it'd just stick in too much. i would much prefer the 35, but i cant have any rubbing. btw, enkei evo5 if that affects anything (i doubt it does). opinions asap plz!!
Old Aug 22, 2006 | 05:35 AM
exige's Avatar
bump!
Old Aug 22, 2006 | 07:11 AM
sky-on's Avatar
you shouldn't, depends on the tires you run on, i have 18x7.5 +40 with 225/40/18 and i don't rub, im on hotchkis as well, i'm changing it out to 18x8 front 18x9 rear soon, i'll let you know if i rub, but with just 18x7.5 you should be fine
Old Aug 22, 2006 | 04:45 PM
exige's Avatar
k...anyone running a 7.5" +35 or something extremely close, on hotchkis? im lookin for someone who's running it to let me know what they think, but chances are ill end up getting it then. i normally dont have passengers in the car either, so no extra weight.
Old Aug 22, 2006 | 05:52 PM
exige's Avatar
bump!
Old Aug 22, 2006 | 08:38 PM
tc2nut4's Avatar
PM zero... hes running hotchkis with 18s... he could tell ya
Old Aug 22, 2006 | 10:07 PM
exige's Avatar
im pm'ed him....bump for some more opinions
Old Aug 25, 2006 | 08:09 PM
exige's Avatar
bump!!
Old Aug 25, 2006 | 08:24 PM
brownbanana's Avatar
i just got some 18x7.5 with +35 offset. I didnt put them on, but ill let you know. Im dropped on stechs
Old Aug 25, 2006 | 09:18 PM
Neothin's Avatar
alright, how about stech drop with 18x7.5 w/ 33mm offset in the front and 28mm offset in the rear?
Old Aug 25, 2006 | 10:18 PM
well, i just put them on a drove them for a couple miles without rubbing issues. will update after more driving.
Old Aug 26, 2006 | 03:58 AM
exige's Avatar
lemme know if they rub in tight cornering situations...like parking lots etc.
Old Aug 28, 2006 | 08:40 PM
It seems like it rubs hitting a little dip going fast and what not in the front. It is really tight. I might have to roll the fenders or something. The rear seems fine. I got the Enkei EVO 5 too. If I were to do it again, I wouldve got the +45 wheels. These wheels look a lot better than my old 18s which had a +48 offset, but those would NEVER rub.
Old Aug 28, 2006 | 09:27 PM
tarheel_tc's Avatar
I just bought some 18x7.5 with offset +45, I will be running 215/40/18 tires, with my Goldline springs (2inch drop F/R). I was told i wont rub.
Old Aug 28, 2006 | 10:40 PM
ah, i doubt youll rub
Old Feb 5, 2007 | 05:36 PM
MAXAM's Avatar
ok so heres my .02 cents... I have 18x7.5 +35 Offset TSW Thruxtons finally settled on some Hotchkis Springs (these really look more like a fat s-tech drop)... well heres how the story goes:
1st Week: Looked Great, No rubbing nor Scraping. I didn't even have to do an S-shaped turn into speed bumps.
2nd Week: Got my Alignment done. Only rubbing when I went over 70+ on little highway bumps.
3rd Week: Finally settled. I can barely fit my index finger into the gap. Looks sick as hell but the driver's side wheel keeps on severly scraping when I turn right & Ever little bump I go over when I drive on CA highways (70+) I get a minor scrape.
Conclusion: Looks great, but if I had to do it all over again. Hotchkis would DEFINATELY not be my choice. Next week I am changing it to H-techs... wutta waste of time and $$$
Old Feb 5, 2007 | 05:38 PM
Neothin's Avatar
^ play around with the wheel wells... I had the same problem when i put on my spacers, and i shoved and bent the wheel well higher and eliminated my rubbing issues.
Old Feb 5, 2007 | 05:52 PM
MAXAM's Avatar
how can i bend the wheel wells? do i need to jack up the car?
Old Feb 5, 2007 | 07:42 PM
exige's Avatar
roll your fenders, yeah you probably wont have any room to work with if you dont jack up the car. and dude to be honest with you, h tech's aren't gonna be very different, if at all. their drops are almost identical. i would go with something like eibach's prokit, trd, or h&r's sport kit. there's a lot of options...check here... https://www.scionlife.com/forums/viewtopic.php?t=89766 . also, if that's a driver's side wheel thats rubbin, h-tech's will drop it .2 inches more than hotchkis does, so prolly not a good choice. before you go out and buy a new set of springs based on the lowering rate, check the dampening rate and reputation. hotchkis has a rep for being sporty, solid, and planted. to the exact contrary, h-tech's have a rep for being extremely spongy and bouncy. read up before you go make an impulse buy. but id roll that fender up if i were you. hotchkis is the way to go.
Old Feb 5, 2007 | 07:44 PM
Neothin's Avatar
i'm not talking abou trolling the fender (thought htat would be a good idea too).
the fenderliner is only plastic, just push hard and it'll bend.
