Exhaust Leak
Old Aug 22, 2006 | 06:18 PM
tc2nut4's Avatar
Default Exhaust Leak
I have the alphawerks header and Megan S pipe, Greddy EVO2 axleback and as of now my OEM mid pipe is back on (Long story don't ask). Sounds nice but here's the problem:
I have a leak at the S pipe and Midpipe gasket. Now I tightened down, and actually I went too tight and cross threaded it
So i tapped it and put new threads, this time put a nut on the otherside and had at it. Thinking it would be better I started the car, climbed under it and to no avail. I still have the leak. I have tried loosening the header bolts to allow some wiggle room to get a slightly better seal at the S and Mid pipe but it still leaks. I'm about to take it to a local shop and just have them weld it because I'm tired of dealing with it, but I want that to be my last resort
Sooo....before I go and do that, I know a few others on here have had leaks at the same location so i was hoping to get some ideas.
Old Aug 22, 2006 | 07:44 PM
tc2nut4's Avatar
bump...
Old Aug 22, 2006 | 09:04 PM
3min3m2's Avatar
make sure u have all 3 gaskets on the s-pipe...mine was a bit^h to install
other then that, good luck
Old Aug 22, 2006 | 09:07 PM
tc2nut4's Avatar
thats the problem... i do have all three gaskets on and its still leaking
Old Aug 22, 2006 | 11:22 PM
3min3m2's Avatar
hum.....unless you have a broken weld at one of the flanges.....you might have to have it welded, just b/c it may be the weld in the pipe....
sorry i couldn't help ya
Old Aug 23, 2006 | 02:36 PM
tc2nut4's Avatar
its cool... at work bump
Old Aug 23, 2006 | 04:15 PM
sp0t's Avatar
do you hear air when you accelerate? i have the zpi s-pipe and i do have a leak right now, but i've grown past the fact that there is one. since heat expands metal, the leak is gone after the car is fully warmed up.. when i start up the car, i dont hear any sign of "air". there's a gap in between the s-pipe and the header because of the gasket, if only zpi made their s-pipe opening a little bigger to sit flush. bleh.
Old Aug 23, 2006 | 04:28 PM
tc2nut4's Avatar
thats whats weird my header and s pipe connection have no leakes, however at the mid and s there is, i hear air when i accelerate but only in tunnelsor under bridges is it audible. When i first start the car is when I can hear a "whoosh" of air come out... bleh i'm just gonna go get it welded i think
Old Aug 23, 2006 | 04:39 PM
exige's Avatar
exhaust cement?
Old Aug 23, 2006 | 04:41 PM
1badTc2-0's Avatar
Go to autozone and buy a tube of RTV compound
tc2nut4's Avatar
uhhh... to be honest I never heard of it, i take it it works just like it sounds, how easy is removal??
Old Aug 23, 2006 | 04:58 PM
1badTc2-0's Avatar
when you want to remove it, its easy. Trust me, it should solve your leaky seal issue, go talk to the guys at autozone they should agree.
Old Aug 23, 2006 | 05:07 PM
sp0t's Avatar
yeah i was thinking about getting that.. whats the difference between the "RTV compound" and Permatex's Ultra Copper Gasket?
Old Aug 23, 2006 | 05:28 PM
Setarcos4131's Avatar
I second the RTV compound..stuff helped me with my exhaust leaks that I had on my megan cat-back.
Old Aug 23, 2006 | 05:32 PM
1badTc2-0's Avatar
Sorry dont have any experiance with permatex. RTV has never failed me though
Old Aug 25, 2006 | 05:21 PM
tc2nut4's Avatar
bump
Old Aug 25, 2006 | 07:43 PM
tc2nut4's Avatar
Old Aug 27, 2006 | 01:59 PM
3min3m2's Avatar
i think mine is starting to sound like this....its like really raspy if you rev it when the car exhaust is cold(no header, just s-pipe, and megan with 2! resonators) but the rasp goes away as you drive around....
wondering if megan didnt align the pipe correctly...
Old Aug 27, 2006 | 03:24 PM
jeremy681978's Avatar
make sure all the gaskets are installed correctly
DaBlackBox
134
Apr 10, 2022 02:04 PM
eric29
15
Apr 26, 2016 07:27 PM
Andreas24
May 17, 2015 09:05 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
