Size of the ZPIracing Oil Return Line
Old Aug 24, 2006 | 07:13 AM
wtc_81's Avatar
Default Size of the ZPIracing Oil Return Line
anyone know the size of the oil return line? is it -10?? thanks
Old Aug 24, 2006 | 08:00 AM
WeDriveScions's Avatar
TADA I Believe it's -10
Originally Posted by ZPI
Oil pressure feeding a turbo is not biggest problem as to why people blow the seals. A lot of time when you add a resistor or they use small hole fittings this actually increase the oil pressure it just lowers the volume. The key is to mate it with the right size return line.
Most people use a small oil return line and the oil can not drain quick enough. It is pressure coming in a gravity taking it out. IF you use a -4 line feeding it you need to use a -10 to drain if you use this you will never have a problem of over oiling the turbo
Old Aug 24, 2006 | 08:55 AM
wtc_81's Avatar
Thanks.. Was thinkin about getting the Stainless steel Drain Line from stealthmode performance.
Old Aug 24, 2006 | 12:52 PM
ERIC-TC's Avatar
Well the return line on my Stage 0 is a 3/4 ID silicone braided hose. About 16" long with a 45-deg elbow and a nipple at the oil pan. This is HUGE compared to the actual oil feed line that has a 1/8 orifice in it -but I like some said you can never go too big on the return line.
Brammi
Nov 13, 2016 03:46 AM
rain7905643
Mar 14, 2015 12:48 AM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
scionlife
Apr 16, 2003 05:13 PM
