Brakes
Old Aug 24, 2006 | 10:52 PM
bubblemyster's Avatar
Default Brakes
First off for a front brake job at the dealership is 160 expensive, or the "going rate". Also is it normal for one side, like the passenger side brakes, to wear significantly quicker than the driver side? Please help/advise.
Old Aug 24, 2006 | 11:55 PM
Z0RACK's Avatar
I'm gonna need more info. Pictures of the old brakes side by side would be very helpful also.
But it depends on what the dealer is doing to your brakes. If it's just replacing the pads and nothing else. Then yes your getting ripped off.
Old Aug 25, 2006 | 12:00 AM
surfcity40's Avatar
Gonna go out on a limb here and suggest that you can do this
https://www.scionlife.com/forums/viewtopic.php?t=86011
A heck of a lot cheaper and even if you buy two jack stands (which I certainly recommend), you will save about a hundred bucks.
good luck.
Old Aug 25, 2006 | 12:04 AM
deathbyc4's Avatar
uneven wear isnt good. if you're changing rotors, might as well change brake fluid and those dreaded rubber lines. get some stainless lines for front and rear, clutch hose if you have a manual. then get some Motul 600 brake fluid, and axxis deluxe brake pads. with all that said, there's money worth spent.
Old Aug 25, 2006 | 12:15 AM
don't have pictures yet, but what usually causes uneven wear. I looked at the pads and could tell just by eye that one side(passenger) side was worn down significantly than the other side(driver). Most of the time I drive, I am alone.
Old Aug 25, 2006 | 05:44 AM
Hyghgynx's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=86011...
Thanks for the link! This will definitely come in handy!
Old Aug 25, 2006 | 05:00 PM
1badTc2-0's Avatar
re-bleed the side thats wearing quicker. Why did you ask your dealership this question while they were ripping you off?
Old Aug 27, 2006 | 11:44 PM
jwaggz82's Avatar
$160 for a brake job sounds about right. 1.5hrs labor and the price of brake pads. ..... but ....it cost me $37 doing it myself.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
