My ZPI S-Pipe Leak
Old Aug 25, 2006 | 04:43 AM
sp0t's Avatar
Default My ZPI S-Pipe Leak
I was able to take pics and sound clips today of my leak around the s-pipe area..
so let's start with the pics:
http://members.***.net/mcayanan/leak1.JPG
http://members.***.net/mcayanan/leak2.JPG
notice that the gasket i'm using is one wide and fat thing.. it works better than the stock donut gasket though.. and Yes, the bolts are at it's TIGHTEST state right now. The reason why the left bolt is more screwed in than the right bolt is because the leak is mostly coming from the left side (closest to driver side) so that fixed it up. I can't feel anymore air, but that annoying "air" sound is still there.. PLEASE tell me it's normal if not, then what can I do? That orange stuff is the permatex ultra copper gasket maker stuff.. but that was there before the shop put that fat gasket there.
Here's the vid/sound clip:
http://www.youtube.com/watch?v=snGrYFE4Fe4
Old Aug 25, 2006 | 04:58 PM
1badTc2-0's Avatar
call ZPI, it should not leak, they might not help you out now though since its been molested by a muffler shop
Old Aug 26, 2006 | 04:17 AM
sp0t's Avatar
since it leaks where the s-pipe flange meets te gasket.. would it be pointless to cut and weld on the STOCK s-pipe's flange onto the aftermarket s-pipe? because the stock s-pipe flange sits perfectly against the gasket.. actually the gasket sits INSIDE the stock s-pipe flange leaving NO gap like the gasket above.. what do you guys think? i might do this with a shop.
or in simpler "terms'..
Old Aug 27, 2006 | 03:27 PM
jeremy681978's Avatar
do you like the s pipe
Old Aug 28, 2006 | 04:24 AM
dstyle's Avatar
i got have that same problem. my stock gasket took a beating but I finally managed to seal it up for the most part. mine leaks on the right hand side though.
Old Aug 28, 2006 | 07:14 AM
sp0t's Avatar
ok so i did weld on the stock flange onto the zpi s-pipe..
it's sealed. no more leaks.
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Hydryman
Feb 23, 2016 03:35 PM
TotalChaos
Jan 21, 2016 11:27 PM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
