Newbie clutch question.
Old Jul 12, 2004 | 11:23 PM
zizi's Avatar
Default Newbie clutch question.
Under heavy acceleration, after I let off the gas and push the clutch I can feel revs under the clutch like the gas is still being applied? Is this normal under heavy acceleration? I am a newbie when it comes to manuals.
Old Jul 12, 2004 | 11:27 PM
surgetC's Avatar
Yes, unfortunately that is a trait of many newer cars; basically, when you let off the gas, the engine's computer keeps the throttle slightly open. This is done for emissions... I'm not 100% sure how it works, but it has something to do with burning residual fuel in the combustion chambers.
You'll get used to it.
Old Jul 13, 2004 | 12:19 AM
SCiONYDE's Avatar
in ter esting
Old Jul 15, 2004 | 02:21 PM
zizi's Avatar
Ok, I shift smooth when releasing the clutch pedal fast. I also read that you should engage the clutch in .5 seconds or faster. Everyone I talk to says to release the clutch slowly when shifting?? When I release the clutch pedal slowly like 2 seconds my car jerks, but when I release the clutch pedal fast, like .5 seconds or faster it is smooth. What is up?
Old Jul 16, 2004 | 04:41 AM
QuestMGD's Avatar
0.5 seconds would be considered "slow" when engaging clutch. This is the time from the clutch starts to engage to full engagement.
I can't imagine even trying to engage a clutch through 2 seconds.
I don't think I've ever timed myself but on my CL I probably engage in 0.1 seconds or so.
In any case, generally driving smoothly is the correct method. As long as you keep it smooth you'll adapt a technique to engage the clutch.
The "BAD" thing for clutches are slippage, where clutch is not fully disengaged nor fully engaged. This causes clutch wear leading to clutch replacement. That's way you are cautioned not to drive with your foot on the clutch all the time.
Good luck, don't worry, you'll figure it out naturally.
Old Jul 16, 2004 | 04:50 AM
zizi's Avatar
When you say you engage the clutch in 0.1 seconds, that means you go from having the clutch pedal pushed all the way down and then released in 0.1 seconds? Is that called dropping the clutch?
Old Jul 17, 2004 | 03:14 PM
zizi's Avatar
Anyone else feel the revs under the clutch under heavy acceleration?
Old Jul 17, 2004 | 03:58 PM
mill0048's Avatar
The main goal is to use the clutch pedal in the shortest interval possible WITHOUT dropping the clutch or producing herky-jerky movements to the driveline/car (which puts added strain on all driveline components). Your best bet is to try to emulate an automatic transmition in smoothness and speed.
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
Ianno
Jul 7, 2015 04:35 PM
