2004-2006.5 [NCP61]
Tanabe springs fitted!
Old Aug 28, 2006 | 11:22 AM
Matt384's Avatar
Default Tanabe springs fitted!
Me again
Springs are fitted! I'll be getting up pics soon, but i've got a question!!
The rear springs seem to have lowered the car alot more than the front ones!
Is it just me or is this possible???!!!?
Someone's also told me that the front springs will not show much of a drop until they settle.... said 2 weeks should have them settled.... is this true??
I'm a lil worried that i made a bad choice of springs
Old Aug 28, 2006 | 11:26 AM
Soon2BxB's Avatar
what tanabe springs did you use
both of the tanabes i saw are about the same between F AND R
NF210 - 1.4 Front and 1.5 Rear
DF210 - 2.0 Front and 1.8 Rear
Old Aug 28, 2006 | 11:28 AM
Matt384's Avatar
Apologes... forgot to mention!
I've bought the tanabe NF210's!
Old Aug 28, 2006 | 11:49 AM
Soon2BxB's Avatar
the difference in the drop between the F and R is only .1 inches ... the rear shouldnt be lower then the front at all considering stock the front is lower then the rear and you only changed that ratio by .1 inches...
post up some pics so we can see what you are talking about
Old Aug 28, 2006 | 12:07 PM
Matt384's Avatar
I just had a look through the tech article and found this:
You can now put the rear suspsension back together. See how easy that was?! Just take note that as with the front, springs will not settle into the proper drop right away. In most cases, it takes about 2 weeks to properly settle to the proper height, though most of the rear will settle while you're working on the front springs.
So I guess it's normal then for the front to look a little higher at first.
Or i could be looking too hard? hmmm
Old Aug 28, 2006 | 01:06 PM
pandaslayer's Avatar
just wait for them to settle.
Also don't forget to get an alignment done in a few weeks. your toe will most likely be off.
Old Aug 28, 2006 | 01:10 PM
Matt384's Avatar
my toe?? hehe and in english?
Old Aug 28, 2006 | 01:27 PM
Toe.
Stand over your front wheels. Imagine that the wheels are pointing outwards, or inwards to your point of view. That's toe. It greatly reduced ride and handling, as well as increased tire wear.
Old Aug 28, 2006 | 03:01 PM
Matt384's Avatar
right ok thanks for that.... so i'll wait for springs to settle...then take it for alignment.
it should need it since ive actually just changed my rims and tyres too!
Old Aug 28, 2006 | 05:06 PM
wheels and tires don't really change the alignment, unless you were meaning that since you don't wasnt to ruin your new rubber.
kleecker
Jan 9, 2015 02:26 PM
GreatWhitexA
11
Dec 23, 2003 05:25 AM
bBOXD
28
Dec 7, 2003 07:08 PM
Besk_one
Oct 16, 2003 07:45 PM
coasterlvr
Oct 3, 2003 09:16 AM
