which fuse do i replace?!?
Old Sep 7, 2006 | 06:28 AM
azynboy55's Avatar
Default which fuse do i replace?!?
my led lights for the cupholders and neon lights for the front of my tC doesn't work. the lights came from the scion dealer and i was wondering, does it mean that my fuse is blown out? if so, can anyone show me which fuse to replace?
Old Sep 7, 2006 | 09:31 AM
SquallLHeart's Avatar
acc fuse.. found in the inside fuse box under where the hood release latchy is.. stick head under there. you'll see it
that or if there's one that says for cig lighter.. i'm a little tired to find out now....
you can always just pull out every fuse and see what's blown...
you plug anything into your cig lighter before it happened?
Old Sep 14, 2006 | 10:49 PM
itstdt's Avatar
i have that blown out too... but i dunno which one it is... how much amp is the fuse?
Old Sep 15, 2006 | 08:58 AM
maybe check #34 or #37..
Old Sep 15, 2006 | 09:04 AM
Scotty's Avatar
mine done the same thing i didnt know if it was the fuse or the switch...i checked the fuses but i couldnt tell if they were blown.
Old Sep 15, 2006 | 06:57 PM
itstdt's Avatar
I have checked every small fuses (not the big ones like 40 or 50 amps) and none of them are blown... but my cig lighter still doesn't work... so what could i do?
Old Sep 16, 2006 | 06:19 PM
itstdt's Avatar
i found the fuse to be replaced
Old Sep 19, 2006 | 02:45 AM
Scotty's Avatar
which one was it???
Old Sep 19, 2006 | 03:16 PM
itstdt's Avatar
i believe it's #23... it's 15amp... u can find that fuse box above the accelerator and brake area... u have to stick ur head under there and look up... there's a box with a diagram of which fuse is which... it's on the left side that said #23 (cig lit) or something like that... check that if it's blown... if it's blown, the middle of the fuse is burned and would turn black... keep us update whether u r able to solve that problem
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
