s pipe mid pipe?
i have the greddy evo axle back exhuast, and i want a mid pipe and s pipe. would the megan s and mid pipe do just fine?(is there any problem with the sensor in the s pipe?) im planing on running a turbo very soo too so im kinda just geting ready for it so im not gona get a header. what else do i need clutch, fly wheel, suspension? any help would be highly appriciated. -thanks
also would it be bad running just the spipe mid pipe and axle back just for now till i get my turbo?(would i be loosing power due to lose of backpreasure) what about sound any deaper or raspy? -thanks again
No, b/c your precat is still constricting your exhaust. You may loose very little in the low end (.1 off of your 1/4 but that's just an estimate).
Your exhaust will sound a little deeper b/c of the slower air flow due to the restrictive "header."
Not sure about the Megan set up but ZPI should work. Make sure the mid pipe you get has a resonator built in or your exhaust will be very ricey.
As for trany upgrades, it's not a bad idea to get a stage 2 (kevlar) clutch and light weight flywheel, although not necessary. The rule of thumb is:
If you plan on doing any racing at the track or a lot on the street, look for a drag clutch.
If you almost do nothing at all other than periodic street light to street light, just get a stage 1.
The fact that you're getting a turbo makes it almost a sure thing you will need a new clutch. Make sure it's drag ready. Kevlar clutches last a long time and you might be able to get a stage 3, 4-6 puck steel clutch as well. Just keep in mind, the higher the stage clutch, the harder your shifting will be.
Good luck.
Good luck.
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
