hood lifting
Old Sep 12, 2006 | 03:05 AM
ljbetances's Avatar
Default hood lifting
what about the jdm thing of lifting the hoods on the part that is in front of the windshield... I know that it would help a lot to keep the engine bay temps low... is there any kit or has someone in here done it.
thanks
Old Sep 12, 2006 | 03:10 AM
davedavetC's Avatar
Old Sep 12, 2006 | 03:14 AM
ljbetances's Avatar
havent you seen the civics with the back part of the hood lifted about an inch or two... its made to lower the engine bay temperature... it does work. does someone have it done or is ther any kit for this??
thanks
Old Sep 12, 2006 | 03:15 AM
tCb00b's Avatar
I think he is talking about putting metal washers on the screws/bolts that hold the hood to the hinges. Thus raising the rear part of the hood to act like a vent for hot air to exit. I'm not sure I would call it a JDM thing but to each his own. I would probably go down to the hardware store and look for some washers that fit the bolts on the hood. Might want to take ONE out to get an idea of what size you need. Personally, I wouldn't do it because I think it would break up the smoothness of the tC's lines.
Old Sep 12, 2006 | 03:17 AM
WeDriveScions's Avatar
We do vented hoods, but most tC guys are not fans of JDM mods in the first place... it'd also pull the hood up above the headlights and would look off a bit.
I've never liked the look on civics, but would strongly dislike it on the tC and haven't seen one with spacers on.
Old Sep 12, 2006 | 03:18 AM
ljbetances's Avatar
thanks. that is exactly what I meant.. I said it was a JDM thing because I used to own a civic and all the forums that I read from (clubcivic.com jdmcivic.com honda-tech.com) called it a jdm thing. About the breaking of the smoothness of the tc's lines im not sure... thats why I want to look at one with it done.
thanks
Old Sep 12, 2006 | 03:19 AM
davedavetC's Avatar
gotcha now
Old Sep 12, 2006 | 03:32 AM
iripthekut's Avatar
there was a guy on here that had a tc that had that. I ws trying to find the pic but its gone. anyways, it looked pretty decent. it did seem to break up the tc lines or anything. it just looked like the hood was raised, which was not too notiable. if you feel that it will help your performance more power to you. i would like to see how it turns out.
Old Sep 12, 2006 | 03:49 AM
ljbetances's Avatar
ok thanks guys... If i decide on doing it I will post pics.
thanks
Old Sep 12, 2006 | 05:23 AM
BuddhasTC's Avatar
unless you have a large amount of hp...there's no need to do that to keep ur engine bay cooler
Old Sep 12, 2006 | 05:51 AM
HKSpeed's Avatar
I had it done to my car. I took it off after I put back my cf hood. cost me about $7-8 in parts because metric bolts cost more (about $1.20 each & 8 cents per washer). i took a stock bolt and determined the size at Ace hardware.
any cooling gains are negliable. 240sx guys (me being one of them) debate over the functionality of it. in addition to venting engine heat, air that enters the engine bay through the grill/radiator has no where to go so you got a parachute effect going on. so in theory hood propping seems like a good idea. Toyotas and Nissans run much hotter than Hondas, so it would be more beneficial for our cars.
Old Sep 12, 2006 | 06:23 AM
Looks somewhat decent... better than I thought it would.
Old Sep 12, 2006 | 06:32 AM
tC9o9's Avatar
i currently am running the washers/bolts that HKSpeed was running, he gave them to me after he put his c/f hood on..
it does make the car look better imho.. as the whole car is raked now.. i got the drop which makes the front a lil lower, the hood is tilted, and the sunroof is tilted so it goes pretty smoothly.
i highly doubt it does anything for performance, but when i finally put my header in, then i will put two or three more washer so that they actually function.
Old Sep 12, 2006 | 07:13 AM
SquallLHeart's Avatar
hmm... some former old batches of CF hoods i know had "fitment issues"..... which were exactly that.... the hood came up at the hinges and weren't flush.
get a hold of one of those?
Old Sep 12, 2006 | 07:19 AM
Functional, and at a discount price.... some CF hood guy is going to remarket them as legit modified hood!
Old Sep 12, 2006 | 07:42 AM
kungpaosamuraiii's Avatar
This sounds like an experiment for anyone with an OBDII reader. We gotta know if this does have an effect on IAT. It'd be cool also if someone has an accelerometer to see if the change in aerodynamics has an appreciable effect. In both cases, I doubt anything much changes. I would love to know about IAT effects for sure though.
Old Sep 13, 2006 | 05:55 PM
HP_Pirate's Avatar
anything to get engine bay temps down sounds good to me.
I may just have to try this and see how it works. anyone with better pics. post em up.
Old Sep 13, 2006 | 06:00 PM
web's Avatar
web
Has there been any development possibilities of making CF hoods with this feature? Kind of a cowl style hood like the old mustangs, but obviously we wouldn't want anything that big. Maybe just a slight hump that runs from edge to edge rather than just about 2 feet in the middle?
Old Sep 13, 2006 | 06:01 PM
Time for me to break out the Reader!
Old Sep 13, 2006 | 06:20 PM
tcengel's Avatar
The simple, easy answer to this is to remove the rubber lining between the hood and the widshield cowl. This leaves a 1" gap for air to be sucked out of. Did this on My WRX and it made a large difference.
