KO4 turbo?
Old Sep 23, 2006 | 02:02 AM
AndrewGene's Avatar
Default KO4 turbo?
Okay, so i'm new to F/I but i have studied about it on here for about 4 months now and am getting to know quite a bit about the different turbo kits for the tC (the pros and cons of each). However, i went to a local shop today and a guy mentioned that maybe a KO3/KO4 turbo might work pretty well....i know nothin about either one so any information would be helpful...thanks guys/gals. BTW, the guy said that those were 2.0L applications and that his shop has not boosted a tC before.....any comments would be greatly appreciated.
And secondly, what other turbos would be good for our car? (Hope that's not too broad a question) The only ones i know of are the ones in the kits (16g, 18g, 20g, t3/t4).
Old Sep 23, 2006 | 02:06 AM
zer0's Avatar
16g is the absolute smallest I would go... K04 is way to small, might as well buy a hairdryer and mount it up..
Ideal is anything 16G or up.. My favorite at the moment is the 18g, but would love a 20g...
Old Sep 23, 2006 | 02:11 AM
AndrewGene's Avatar
why a 20g? The guy at the shop said that a KO4 would render about 320whp but that might be at a lot of psi.
Is a KO4 at 20psi worse on an engine than a 16g at 12psi (rough numbers but roughly the same whp--i think)? I figure it is worse since it's 6 pounds more pressure.
Old Sep 23, 2006 | 02:14 AM
zer0's Avatar
The k04 is rated at 225hp... 18g=400hp 20g=450ish..
A 16g or 18g will put you at 240whp with stock everything else.
Old Sep 23, 2006 | 03:22 AM
soros151's Avatar
I would say an 18G would be the ideal mid center in case you later want to up the boost. It can go from 7-8psi all the way to 30ish something psi. But I would use that turbo for those high psi levels. A 20Gwould work wonders there.
Old Sep 23, 2006 | 04:50 AM
lightwarp's Avatar
k03/04 are popular among audi and vw. the B5 body S4 is bi-turbo charged with k03 US, k04 Euro spec. those things spool fast, you get a flatter than flat torque curve. they easily run 300 ~ 450 hp, but that's 2 k03/04, not 1.
with all that said, unless you are going to run a bi-turbo set up, listen to what ppl posted above and go bigger.
Old Sep 23, 2006 | 06:08 AM
AndrewGene's Avatar
What about the answer to this question....
Are a 2 KO4s at 20psi worse on an engine than a 16g at 12psi (rough numbers but roughly the same whp--i think)? I figure it is worse since it's 6 pounds more pressure.
And what other turbos might work on our cars...i just kinda like to be different.
Old Sep 23, 2006 | 01:43 PM
zer0's Avatar
its not about psi, its about CFM and if our cylinders can handle it.
Old Sep 23, 2006 | 05:31 PM
soros151's Avatar
^^^Also VERY true.
Old Sep 23, 2006 | 05:51 PM
lightwarp's Avatar
1. cost
2. reliability
3. power
4. different
choose 2, and lose the other 2.
Old Sep 23, 2006 | 11:58 PM
Rasta's Avatar
For real LOL
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
