4CH amp upfront.
Okay here's the deal.
Not wanting to loose trunk space or having wires running to the back, I'm asking for suggestions of where to put the amp upfront, this way I won't have to run the wires from the HU to the trunk to amp and then back to front speaklers. I can just keep the amp ion front and run it from there right?
So.. where to hide it.... glovebox?
if you can get a four channel in your glovebox... more power to you... but in reality.... you more than likely will not be able to ... you could try under your pass seat... but even that will prolly not work... i know you dont want to run it to the back .... but thats the best place and you could hude it under the mat on the pass side in the foam like so many SL'ers have done...
Mount it behind the body panel in the rear seat/speaker area. I know others have without any heating issues. The only problem is that once you get it set, you have to remove the panel to adjust it. But it hides it and keeps it out of the way.
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
