shocks blown out?
Old Oct 15, 2006 | 04:24 AM
theblue's Avatar
Default shocks blown out?
I had trd springs installed around three months ago (~3,500 miles). I didnt go with the trd shocks, just kept the stock ones on. Everything was fine with it, no sounds at all. However, a week or so ago, every time I would go over a steep speedbump, even at slow speeds, I would hear a clanklike sound coming from the front left wheelwell area. Is it possible that the spring just popped out of place, or the shocks are out?
Old Oct 15, 2006 | 04:40 AM
steve_r's Avatar
do u feel a difference when driving
Old Oct 15, 2006 | 04:42 AM
theblue's Avatar
no difference during driving, just an annoying sound from the front left wheel well on hard speedbumps.
Old Oct 15, 2006 | 05:28 AM
KINGxOFxSKA's Avatar
Unique Scionikz
Push down hard on each of the 4 corners of your car. If a corner keeps bouncing and does not sit back into place after pushing down on it then yer shock is most likely blown.
Old Oct 16, 2006 | 02:26 PM
krdshrk's Avatar
I'd tighten the large nut at the top of the strut tower - it might be loose and that might be what's making the noise.
Old Oct 16, 2006 | 02:58 PM
phungy's Avatar
I have a slightly similar problem but mine is the driver's side rear making a clanking sound when I make left turns. Tighten the nuts?
Old Oct 16, 2006 | 03:09 PM
krdshrk's Avatar
First thing to do is to tighten all the nuts... but if it's clanking, i'd take off the wheel and check to make sure everything's tight/connected in the back..
Old Oct 16, 2006 | 03:39 PM
Nick06tC's Avatar
If they are blown, I will sell you a set.
Old Oct 21, 2006 | 08:07 PM
jobunaga's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=138410
Tighten the bolts on your upper strut assembly.
Old Oct 21, 2006 | 11:05 PM
tc2nut4's Avatar
if your car rides like this then your struts are out
Old Oct 27, 2006 | 01:06 AM
LED-Maniac's Avatar
yowza!!!!!! i think an overhaul will be neccessary ;)
Old Oct 27, 2006 | 01:16 AM
phungy's Avatar
LOL.
Old Oct 31, 2006 | 08:09 AM
amanda776's Avatar
I had the same exact problem - twice. Both times it was a loose bolt so try checking that first, like krdshrk said.
Old Nov 7, 2006 | 03:57 AM
darkalice's Avatar
i'm having that problem with the rear but it sound like "popping" noise. is that the sound of a blown out shock or something else?
Old Nov 7, 2006 | 04:19 AM
DonnyDarko's Avatar
Are all of u on TRDs?
Old Nov 7, 2006 | 05:35 AM
amanda776's Avatar
I am.
Old Nov 7, 2006 | 01:57 PM
samichmansTc's Avatar
Marvelous Scions
well i'm having some problems with my tc as well. i have all OEM shocks and Springs nothing changed, but when my car sits for a while and i go to drive it i hear this rubbing or clanking sound at the rear of my car where the wheels are anyone know what it could be? plz Help...
Old Nov 7, 2006 | 04:06 PM
phungy's Avatar
Try tightening the bolts?
Old Nov 9, 2006 | 04:18 AM
XD40tC's Avatar
Check yer sway bar too! Make sure its tight.
Old Nov 9, 2006 | 11:53 PM
ESEMRFOZZ13's Avatar
if you use the parking brake it could be from when you disengage it, mine does this and its a stock 07'
