Engine lights
Old Oct 21, 2006 | 08:11 PM
tallguy4u2luv's Avatar
Default Engine lights
I just had the engine light, The VSC light and the Traction control off light come on.....anyone know what givews....the abs is now out of the car!
Old Oct 21, 2006 | 08:52 PM
BKCXb's Avatar
Default Happened to me after I cleaned my calipers to paint them.
Just take out your ABS sensors one at a time and wipe them with a rag. It happened to me after I painted my calipers. The brake cleaner washed small metal shavings down to the wheel speed sensors. Since the tip of it is magnatized they stuck and stayed there. I would start by checking the front, they are easyest to get to. Just one 10mm bolt on your spindle between the strut and the steering arm. You don't even need to take the wheel off. just might have to jack the front alittle if your lowered. Turn all the way one way and reach behind your wheel on the backside. Some wheels like mine you can do it from the front. After cleaning the front reset the ECU and take it for a ride, mine never showed back up after doing this.
Old Oct 24, 2006 | 03:55 AM
firesquare's Avatar
Default Re: Happened to me after I cleaned my calipers to paint them
its covered under warranty. dont dismantle anything! unless you did something
Old Oct 24, 2006 | 04:20 AM
OldYeller's Avatar
Go to the search box, type VSC and read several of the posts on this subject. There are LOTs of reasons those lights go on. It could be your gas cap, your alternator, your oxygen sensor--in other words---lots of reasons. If you have not installed a intake or some other mod--take it in and let Toyota take a look...........
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
Hardhitten
15
Nov 24, 2003 05:38 PM
