Regional - Pacific Northwest
ID, OR, WA
Wanna help with security install?
Old Nov 9, 2006 | 06:32 AM
Song0330's Avatar
Default Wanna help with security install?
I purchased a Clifford Matrix RSX 3.5 security system back in July only to discover that people were charging nearly the same price to install it.
I've been putting it off until I had extra money lying around, but I won't be able to wait for long. The nature of my job requires that my car have a higher level of security during the busy (and dark) winter months. Plus, remote start might be nice so I don't have to freeze waiting for the car to warm up.
Can anyone help me install my system? I'd tackle it myself, but it'll go quicker with two people and I don't want to risk messing this up. I'll buy you lunch/dinner for your trouble.
Old Nov 9, 2006 | 06:51 AM
kkawana's Avatar
hmm.... i dont know if i could help... i do know some1 who probably could..... i should know more this weekend.... he's currently recovering from surgery... may not be super agile... but should be able to help do stuff and or point and say "connect that here"... etc...
i'll look into to asap.... only down side is, you'd have to bring your car down to fed way area
Old Nov 9, 2006 | 07:13 AM
Song0330's Avatar
Not a problem, I love to drive! I'd be willing to go as far north as to Bellingham, or far south to Olympia. As long as the person knows what they're doing, I'll be happy.
Old Nov 9, 2006 | 07:14 AM
neolusions's Avatar
i lend a hand... but keep in mind, i know nothing about alarms....
Old Nov 9, 2006 | 11:57 PM
Kanchi's Avatar
I'm not too great with electrical but if I can help I'll try...
Old Nov 10, 2006 | 03:58 AM
Derk-xB's Avatar
Never installed an alarm, but I'm good with electronics. I could use it as an excuse to meet some Scion folk.
Old Nov 10, 2006 | 04:05 AM
professor-xb's Avatar
Default umm...
i dunno what you need ,
but i have done this stuff for 20 years , if you need vehical specific wiring and and stuff and need suport , i think i can help
Constant 12 volts RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLUE IGNITION SWITCH HARNESS
Starter GREEN IGNITION SWITCH HARNESS *
Dome Light ORANGE (DR) BLUE (PAS) (-) BEHIND JUNCTION BOX **
Trunk Pin Switch VIOLET (-) BEHIND JUNCTION BOX **
Parking Lamp BROWN (-) STEERING COLUMN HARNESS
Power Lock RED 20 PIN CONNECTOR IN DRIVER
Power Unlock PINK KICK PANEL *** #201
* Second Starter Wire- BLACK At Ign Switch Harness.Required For Remote Start ** Junction Box Found High In Driver Kick Panel. *** RED Lock Wire Changes To GREY After Connector, And PINK Unlock Wire Changes To VIOLET After Connector #201- See Negative Pulse Door Lock Diagram
Alarm
Click Here For Our Databus & Immobilizer Bypass Cross Reference
View Diagrams
Accessories
Window Up D\YELLOW P\YELLOW @ EACH SWITCH
Window Down F/PINK F/GREEN #211
Ign Key Warn BLACK (-) STEERING COLUMN HARNESS
Trunk Release ORANGE (-) AT SWITCH
OEM Horn WHITE (-) STEERING COLUMN HARNESS
Headlights VIOLET (-) STEERING COLUMN HARNESS
OEM Alarm Arm NO OEM ALARM PRESENT
OEM Alarm Disarm IN FACTORY SCHEMATICS
#211- See Reversal Rest At Ground Window Diagram
View Diagrams
Remote Start
Tach Signal BLACK 22 PIN CONN LOW IN DRIVER KICK PANEL
Ignition #2 YELLOW IGNITION SWITCH HARNESS #239
Ignition #3 N/A
Accessory GREY IGNITION SWITCH HARNESS
Neutral Safety NON-GROUNDING TYPE
Brake Light BLUE (+) AT SWITCH ABOVE PEDAL
Reverse Light PINK (+) 12 PIN CONNECTOR ABOVE GLOVE BOX
Rear Window Defrost PINK (-) AT SWITCH
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
Beesh
Jan 9, 2015 06:30 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
