DIY Walkthru in progress--tC Light up door sills.
Old Nov 14, 2006 | 05:45 PM
CXT's Avatar
CXT
Default DIY Walkthru in progress--tC Light up door sills.
Supplies needed
Drill bit
Door sills
connectors
Prepping the area
First you remove the factory door sills because these are replacement pieces.
Before
After
You will need to lift the rubber weather striping, and the interior door sill in order to run the wires.
Note the black dot in the picture below. This is where you will drill a small hole to run the wiring into the car. The door sills are placed to give you an idea where the hole should be in relation to the sills.
Drill the hole out making sure not to leave any sharp edges. Clean up the whole area. Wipe the surfaces that will come in contact with the tape with alcohol then allow to dry.
Attaching door sills
Running the wires
Attaching the wires
Old Nov 14, 2006 | 07:44 PM
Fsu1dolfan's Avatar
Cant wait to see it finished!!!!
Keep up the good work CXT!!!
Old Nov 14, 2006 | 08:37 PM
rvpps2rocks's Avatar
where did u get the door sills from?
Old Nov 14, 2006 | 08:44 PM
CXT's Avatar
CXT
Theres a thread on the door sills. Sponsored section I think. Do a search
Old Nov 20, 2006 | 12:14 AM
Fsu1dolfan's Avatar
Any updates???
Old Nov 20, 2006 | 12:22 AM
MyScionVVTI's Avatar
Old Nov 20, 2006 | 02:55 AM
CXT's Avatar
CXT
Sorry I spent this weekend putting on my underbody LEDs
Old Nov 20, 2006 | 02:56 AM
Neothin's Avatar
*you*?
well... the tubes you did at least ^^
Old Nov 20, 2006 | 03:10 AM
CXT's Avatar
CXT
LOL!
Hey man I own you one...or 2
Old Nov 20, 2006 | 03:24 AM
arbnpx's Avatar
Awriite, getting closer to the release of the sills (I'm on the list for a pair of red ones). Do you suggest sealing the hole with silicone or some other sealant, since it will effectively be a hole outside the seal of the weatherstripping?
I'm also looking forward to the wiring part, specifically which circuit will feed the sills.
Old Nov 20, 2006 | 03:27 AM
CXT's Avatar
CXT
Actually the hole is in between the weatherstripping so there shouldn't be a problem.
Old Nov 28, 2006 | 01:27 PM
Fsu1dolfan's Avatar
Any new progess....really would like to see the rest of this done!!! I would like to get a pair myself....but it depends onn you man!
Old Nov 28, 2006 | 05:29 PM
ashuras's Avatar
I have some already. I'm going to install them this weekend. So, if you don't already have picture updates, I'll post pictures of mine after an installation.
Old Dec 4, 2006 | 02:36 PM
Fsu1dolfan's Avatar
3 weeks and still waiting?? Whats new??
Old Dec 4, 2006 | 03:08 PM
CXT's Avatar
CXT
Whats new?? Well......Igot an RS4!!!
November/December is a really busy month for me so please be a little patient with me.
Old Dec 4, 2006 | 03:30 PM
Fsu1dolfan's Avatar
No prob man....i understand...i think most people are.....but im a like anixous to get these and how you got it together!!! Keep us posted thanks
Old Dec 4, 2006 | 09:33 PM
ashuras's Avatar
I finished installing mine, but one of my transformers smoked (not sure how). I'm replacing the transformer and hoping I don't have a short somewhere that killed it.
Installing these things is SUPER simple if you see the picture that I think CXT posted a while back showing where the positive and negative connections go to tap into the dome lights that activate when you open the door.
It was as simple as drilling holes large enough to put the connectors through the lip that the weather strip sits on, then running the connections under the strip that leads to the panels on the driver and passenger side of the floor, where you can leave your little black transformer box (maybe 2" squared) and the wires just need to connect to the documented spots in the fuse box.
All I needed to get were some terminal clips from Radio Shack that I crimped the wires onto for the positive connection and the negative connection was already spliced for my security system, so I just soldered the negative wires together and onto the wire and insulated.
It's a pretty simple install, but I'd recommend a fuse for sure :-) I didn't have an appropriate fuse on hand, but who knows, it might have saved that transformer if I really did have a short that killed it. I suspect that my transformer was a dud though.
Anyway, at least the driver side looks pretty cool at night. During the day, the blue EL tape you can see under the seal doesn't look that hot (little flashy for my taste), but it's cool nonetheless.
Old Dec 5, 2006 | 02:14 AM
CXT's Avatar
CXT
This is the picture you are referring to.
Did you wire both sides to that?
Because I beleive I found a spot on the passengers side to wire that side, and not have to run the wires.
How about some pictures? I am curious as to how the final product turned out.
Old Dec 5, 2006 | 02:24 AM
paul34's Avatar
whoa, before I remembered your other post, I suddenly thought of this:
414 hp/317 ft·lbf of raw German fury
Old Dec 5, 2006 | 02:34 AM
CXT's Avatar
CXT
LOL Nice.
