I rub with a 35 offset....someone help me
Old Nov 17, 2006 | 02:32 PM
Pannyman's Avatar
Default I rub with a 35 offset....someone help me
I used to have a set of 17x7 Shik's from wheelmax and the offset was 40
Recently bought some flick bullet's with a 35 offset but they rub when I turn the wheel
about half-way....don't kow what I am rubbing on but I can definetly hear something bad sounding........its not the tires
I have a 2 inch drop with a 215-45-17 tires
Also what would be better for a better rim a 40 or 42 offset
Can someone please help me with my 35 offset rim question otherwise im selling them cause I can't figure it out at all.
Old Nov 17, 2006 | 05:07 PM
Boxer_Rebellion's Avatar
Try a 5mm spacer to start, see in you are still rubbing.
Old Nov 17, 2006 | 06:15 PM
kenr74's Avatar
Your tire is almost an inch taller than stock. I had some 225/40/18 with a 42 offset and had rubbing in front. A stock size tire was fine though. Crank your wheel and park it. Check the inside of the tire where it meets the back side of the fender. Probably rubbing there.
Old Nov 17, 2006 | 06:29 PM
Pannyman's Avatar
Kenr74 I doubt it since I rub not even at full turn and I had previously run a 40 offset with the same set-up with no problem except at full lock.so even though it may seem possible I have concluded thats not the problem...try to get a spacer thanks anway
Old Nov 17, 2006 | 06:57 PM
Are you sure it's not 42 offset? that's all I see on edgeracing.com for the Bullet.
Old Nov 17, 2006 | 07:28 PM
Pannyman's Avatar
nope i just wrote the wrong one in the begining...its the matte black one.the flik ftd
Rob54Monty
Jan 20, 2016 01:41 PM
terrye
Sep 26, 2015 12:24 AM
jtucker7
Apr 8, 2015 05:41 AM
meowtc
Mar 5, 2015 02:28 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
