Urgent Question!
Old Nov 19, 2006 | 06:16 AM
soros151's Avatar
Default Urgent Question!
Will 2AZ-FE Head from a Camry Engine fit a Scion tC engine!? Please answer me as soon as u can!
Old Nov 19, 2006 | 01:24 PM
sddykstr's Avatar
I'm pretty sure, but not 100%
Old Nov 19, 2006 | 03:12 PM
soros151's Avatar
Dang, Someone was selling one for $180, but now that I'm not sure, I won't buy it.
Old Nov 19, 2006 | 06:19 PM
sddykstr's Avatar
Sorry I couldn't help ya out more. I didn't say I was positive because Im not.
Old Nov 19, 2006 | 11:51 PM
soros151's Avatar
It will not fit, for the main bearing and the rod bearings are different part numbers, they will not fit.
Old Nov 20, 2006 | 01:10 AM
Baron1C's Avatar
what do main, and rod bearings, have to do with a head? people have been swappin heads around for ages, take honda for example 1.8 heads on 2.0 "b" clocks, and 2.0 heads on 2.4 "k" motors, chevy, 327, 350, 383 basically same block, diff bore and stroke, heads have been mixed and matched all over the place,with success. our cars are based on toyota solaras, which started out as a 2 door camery, and they use the same 2.4 cyl. engine? same egine code right??? i don't see why not, if you need a head that is preety cheap, now model year will play a big affect on if it will for or not. the engine might have been revised, but retain the same engine code. so do some more home worke first, but i don't see a problem with it, i have been going to school for automotive tech nology for years, and id seem like it would work.
Old Nov 20, 2006 | 01:31 AM
gjpjr84's Avatar
the tC didnt come from a solara. Avensis.
Old Nov 20, 2006 | 03:28 AM
soros151's Avatar
ZPI tried using on the head different parts to replace some damaged ones, they discovered that some components did line up and did not fit. Old Thread, I remembered that, and the thought tha maybe this wouldn't bolt right up.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
