problems with door locks
Old Nov 20, 2006 | 03:41 AM
jwaj2002's Avatar
TOCC
Default problems with door locks
ok, I've had my box a year, and now that its dropping into the 30's and 40's at night I'm noticing when I get up in the morning and go to my car the drivers door won't unlock, sometimes I can reach through and pull it up to unlock it manually, the key however never works when its cold, and the remote, even the alarm remote, only half unlocks it, I've had to climb through from the passenger's side several times now, and was wondering if anyone else has had this problem, because I really don't want to have to deal with my dealer's snobby "we can't replicate the problem" attitude anymore
Old Nov 20, 2006 | 06:49 PM
grizzly_choppers's Avatar
I have had the problem this winter too. Unfortunately, I know exactly what my problem is. It appears that my SuperFa lighted door lock **** is just a tiny bit tight in the sleeve. When it's cold (only in the early morning so far) the damn thing won't unlock fully with the remote. If I put the key in though and twist it works fine.
So my problem is aftermarket parts. This didn't happen last winter when I had the stockers in.
How close are you to the MO border? If you're within driving distance check out Reliable Scion in Springfield, MO. Scott Horberg will hook you up with the right guy in service.
If you want to check the problem out yourself, you can easily pull the door panel and unscrew the lock then check the friction of the lock in the sleeve. There are some small guide bumps in that sleeve that you could probably dremel out if I remember right. That's my plan. Wish me luck!
Good luck to you too!
-Alex
Old Nov 21, 2006 | 03:01 AM
jwaj2002's Avatar
TOCC
I'm 5 - 6 hours away, I'm actually an hour away from the nearest toyota dealer, and I'm going to drive 2 hours to go to a decent one
DaBlackBox
134
Apr 10, 2022 02:04 PM
mischadoll
Mar 9, 2015 05:48 AM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
