Pics of stock height xB with 17x7 with 205/40/17....
Old Nov 25, 2006 | 04:39 PM
MCC's Avatar
MCC
Default Pics of stock height xB with 17x7 with 205/40/17....
I bought Bbist's Zauber 17x7's and ordered a set of Nitto NeoGen 205/40R17s ---Now I have to wait to get them in and mounted up--- I have a stock height PW xB and wondered if anybody would be so kind as to post up pics of their stock height xB with 17's and 205/40's installed. I hope I don't have a rubbing issue with the wheels having a +42 offset, as I don't want to use spacers if I don't have to. Post them up....!!!
Old Nov 25, 2006 | 05:45 PM
CozShnoz's Avatar
I'd really like to see this, as well! Sounds just like me: I have a stock PW xB and am buying 17x7 w/ +42 wheels from my dad and will be getting 205/40 tires for them.
Old Nov 26, 2006 | 07:26 AM
bB2NER's Avatar
Music City Scions
You won't have rubbing issues at stock height. But those tires are under weight rated for the xB. I tried buying that size from Tire Rack and they wouldn't sell them to me because I told them they were for an xB. Stick with either 205/45 or 215/40. They cost more but won't cause problems with overloading the tires.
Old Nov 26, 2006 | 05:39 PM
MCC's Avatar
MCC
That's funny, because the 205/40 R17 Nitto Neo Gen is load rated at 84 -- and so is the stock Goodyear Eagle LS that came on my box-- I think somebody just wanted to sell you some more expensive tires....
Old Nov 26, 2006 | 05:56 PM
bighvyxb's Avatar
here is mine at stock height but mine are 215/40/17. just a little WIDER
Old Nov 26, 2006 | 06:14 PM
bB2NER's Avatar
Music City Scions
Maybe it was the fact that I was trying to buy Kuhmo 711s in 205/40/17.
Old Nov 26, 2006 | 10:35 PM
MCC's Avatar
MCC
Thanks bighvyxb -- Looks great...
Jethro b-- You are probably right about the Kumhos--I looked at some other brands and found that they had a 80 load rating, which would be too light for the xB.
Old Dec 2, 2006 | 05:59 PM
CozShnoz's Avatar
If it helps, I had 215/40/17's put on 17x7's this morning. There's 4 pics here: http://www.cardomain.com/ride/2508531 and if you'd like to see more, shoot me an email and I'll send them over. Kinda wish I would've gone with 205's though...
Old Dec 2, 2006 | 11:01 PM
bB2NER's Avatar
Music City Scions
But Why? The 215/40s better match the height of the stock 15s and give you added pothole protection.
Old Dec 3, 2006 | 02:45 PM
bighvyxb's Avatar
205 refers to the width (205mm ) 215 is a little wider . 45 vs. a 40 would be a better ride. 215/45/17 or 205/45/17 is the better ride.
Old Dec 3, 2006 | 03:24 PM
bB2NER's Avatar
Music City Scions
I'm slow but got it now You meant 205/45 instead of the 215/40s
Old Dec 3, 2006 | 09:14 PM
kenr74's Avatar
I'm not at stock height but I do have the 205/40/17 with 17x7 rims. No rubbing at all. When these wear out I'm going with the 215/40/17 tires.
Old Dec 4, 2006 | 02:44 PM
CozShnoz's Avatar
True, but to me the 215's on 7" wide rims just look kinda funny. Then again, I'm just used to seeing the rims on my Subaru.
Also true, but I was going to go with a 205/40 so it looked proper on the 7" wide rim. But you're right - the ride would be better with a 45% sidewall height.
bighvyxb meant 205/45, I meant 205/40. :D
Old Dec 4, 2006 | 07:22 PM
grizzly_choppers's Avatar
Here's the wife's:
-Alex
Old Dec 6, 2006 | 03:09 PM
jsnhawkins's Avatar
Okay I'am confused i have a stock height xb, and I'am wanting to put some rims on it. I was thinking about a set of 17x7 icw odessa with some nankang NS-1 215-40-17. What size offset should i get ? Should i get a different size rim or tire? I'am not going for anything special I just want them to look good and have a good rib with no rubbing or clearnce issues
Old Dec 6, 2006 | 04:06 PM
You should be okay with a 42mm or less offset on those.
On a 7" wide rim you should probably run a 205 tire though. 215 will probably work, but the person mounting them will _____ at you a bit.
Rubbing and such won't be an issue.
-Alex
Old Dec 6, 2006 | 07:46 PM
CozShnoz's Avatar
Default I have 215/40 on 17x7
Here's my thread: https://www.scionlife.com/forums/viewtopic.php?t=150999
jsnhawkins - you might want to search "Nankang" though and read up. I was going to get those, but the reviews made them sound really hit or miss! FWIW my rims have a 42mm offset and I think they look cool and all, but I'll definately be researching spacers because they look "sucked in" in the front a little bit and really bad in the back.
grizzly_choppers - why would the tire guys "biscuit"???
Old Jan 4, 2007 | 03:16 AM
MCC's Avatar
MCC
Finally got around to posting these--sorry for the poor light...
scionlife
371
Jun 2, 2015 11:00 PM
SloTC1
Apr 2, 2015 07:11 PM
XBEEZY
Scion xB 2nd-Gen Wheel & Tire
Feb 21, 2015 01:38 PM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
