In dash DVD units...I'm having install problems. Help!
Old Nov 28, 2006 | 08:11 PM
lowdownthrowdown's Avatar
Default In dash DVD units...I'm having install problems. Help!
I just picked up a Clarion MAX675VD in dash double din DVD unit. First off, it sits further out than the stock stereo, so the Scion cover door won't close. Is there a different set of mounting brackets you guys used for your units to get it further back or do I have to drill new holes in the stock bracket? Also, what did you use to connect the stock wiring to the new stereo? I was trying to do this myself, but I'm stuck. Figured I'd ask the pros here before dropping the car off and paying some crazy amount to get it installed.
Thanks!
Old Nov 28, 2006 | 08:37 PM
Spect2K3's Avatar
You have to use the stock brackets. One setting is too far back, and the other is too far in. The resolution, is drilling a new hole on both sides to mount the dvd unit into. Just make sure that they are completely level, my unit is actually SLIGHTLY slanted to the right and nobody sees it but me, but it drives me crazy. So just drill some holes, but make plenty of measurements first. I'm using the stock brackets and the door opens and closes perfectly and it is in the exact spot that I want it.
I'm not familiar with clarion, I use eclipse which is basically made for toyota/scions, so its basically plug and play with the stock wiring
Old Nov 28, 2006 | 09:13 PM
SquallLHeart's Avatar
need to drill holes.. and get a wiring harness kit... metra. all toyota's use the same plug.. just hook up harness to stereo's wires.. and then plug it into the car.
Old Nov 29, 2006 | 02:30 AM
For the GROUND WIRE from the stereo, do I just screw that into some metal somewhere? Also, there is a GROUND WIRE that's on the wiring harness which connected to the stereo. It's a lot shorter. Do I connect this to the matching black GROUND WIRE coming from the stereo or does it not matter if they touch? This also needs to be grounded, correct?
Old Nov 29, 2006 | 02:38 AM
caveman's Avatar
1UP Crew
For mine, I took the ground wire from the unit and wrapped it around a screw on the left side.....
sorry I do not remember about the other ground wire though.....but I believe u connect the black ground wire to the stereo....(correct me if im wrong)
Hope this helps though.....
Old Nov 29, 2006 | 07:44 AM
Thanks for the tips, guys. I got it installed.
Question: How long can I play a movie with the car off before killing the battery? I had my interior lights on (LEDs) and the radio playing for about half an hour, while adjusting the settings. Then I played a movie for about half an hour. I went to start up and my car wouldn't start. It did before, so I know I didn't ____ anything up. I think I drained the battery, though. How long do batteries usually last? Was it already on the way out or do these screens really eat juice?
Old Apr 21, 2007 | 01:55 PM
tcdrummer's Avatar
soooooooo, im looking for a new HU, and i'm looking at the pioneer Avic d2, or d3, but i don't like how the d3 doesn't flip down, and has a smaller screen. i was wondering what HU's are completely plug-n-play, and work with the steering wheel controls withought having to buy extra stuff? and hopefully with NAV and DVD capabilities...
thanks
Old Apr 21, 2007 | 03:04 PM
Neothin's Avatar
^eclipse, but there are modules that allow you to retain wheel controls with other brands.
nebster's Avatar
dude why did you bump this thread. theres no need for that
Old Apr 21, 2007 | 03:06 PM
Neothin's Avatar
meh, bump old thread > make new one
Old Apr 21, 2007 | 03:32 PM
nebster's Avatar
agreed but he could have searched no problem
Old Apr 22, 2007 | 05:59 PM
tcdrummer's Avatar
does the Eclipse AVN5435 work in the tC? and the steering wheel controsl will still work? i think thats my favorite, whats everyones opinion>?
thanks
Old Apr 22, 2007 | 06:06 PM
tcdrummer's Avatar
im also tied up between the Clarion MAX675VD, both of them are amazing... any thoughts? and does the stock "AUX" port in the tC (where i plug my ipod in) connect to either of these HU's? or do i have to buy exttra ipod stuff?
thanks again
Old Apr 22, 2007 | 06:37 PM
Spect2K3's Avatar
thanks
Yes it works great. The sw controls are plug and play. Its an awesome unit. Check my profile for pix!
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
O5_TRD_tC
Feb 18, 2015 09:01 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
